Thank you for your testing, “random restarts” is the too generic case, it would be nice what is happening on Ubuntu since you are saying “heavy load”. What the user suggested? Can you share the link? I wonder if you are performing something “heavy load” on CoreELEC as well. Ideally, it would be nice if you can capture the kernel logs while the system gets heavy load and kernel panics.
EDIT: if you are facing an issue of Ubuntu or system error rather than Kodi or multimedia, it would be good idea to visit the ODROID forum and start your thread. That way, you could have more support.
While @Ray preparing to add it, you can add it to the same quirk to boot.ini for the testing. By the was which USB devices are you running and how many?
Thanks! On my Ubuntu n2 there is one hdd. On my Coreelec n2 there is a USB dvb-s2 tuner (Sundtek Ultima 8) which gets randomly disconnected when not connected to the otg USB port. There is a another rf USB for the remote connected.
I just installed the 190705 nightly. I hope the changes are in there, I don’t understand the changelog of the nightly anymore since it is not showing only recent changes.
I guess changes are not applied yet like Ray said, please do test with Ubuntu image or later when CE nightly image is landed. One suggestion is to join the thread in ODROID forum, not here since USB issue is very specific and can interrupt other issues as well.
Ok, then let’s keep tracking the USB issue on there only.
I don’t like to break the issue tracking here because of USB, this thread should focus on the issue of CE OS features.
IMO, the issue should not matter of a storage and a tuner. But the change or the solution from Amlogic is intended to a storage since the issue was reported with the log of storage failure. I just hope the update of U-boot can improve the USB device connection.
My new N2 has arrived and I installed nightly 2019-07-06.
I have 3 problems, which do not occur with my BeeLink MXIII II (S905X) box and the latest nightly:
I am using Confluence. If the active cursor is placed on a movie-cover in the ‘last added window’ and
the movie title is long so the title scrolls, the gui freezes until the scrolling of the title stops after 3 cycles. The movie can only be started when scrolling has stopped. This happens in each GUI-window, where text scrolls (e.g. movie descriptions). With boxes other than N2 I had never had this problem (new kernel?)
My N2 is connected via a Bose SoundTouch AVR to my LG 79UF8609. Playing 4K-movies is no longer possible (‘no signal’ message on TV).
dispinfo when GUI is active (1080p@50Hz): http://ix.io/1NYP
dispinfo when playing a 4K movie with 2160p@23.976Hz: http://ix.io/1NYQ
It is not a HDMI-cable problem, the same cables work with my S905X-boxes and the generic-nightlies.
In System/CoreELEC settings the force422-option has vanished. This option was required for my LG to play 4K-HDR@50Hz content.
How can force422 be enabled again?
This sounds like a Kodi/Skin issue. Try to confirm with same Kodi version on PC.
2 & 3. As a temp solution you try this in SSH: echo 422 > /sys/class/amhdmitx/amhdmitx0/attr
