Raise a support ticket with ffmpeg and provide a small sample file with an Auro3D codec track.
I only have one release with Auro from 2015 but I can’t find the disc. All my discs are packed in my garage after a recent house move. I had a quick look but some of the boxes are on a top shelf out of easy reach.
I’ve got a question regarding “power on USB-Keypress”.
I’ve got small wireless remote keyboards for all my N2s; they are connected via USB-Dongle.
So do you think there is any possibility to power on the N2s via keypress (would require USB ports being powered all the time)? <- my NUC supports that …
Thanks in advance!!
It would be possible but it would require changes in the bootloader, power is killed to the USB ports during standby and as such you can’t wake the device up via it, this was done so USB hard drives would not carry on spinning during sleep.
On a NUC it is configurable in the BIOS whether to supply power to USB during sleep states.
I was already thinking about in the past to make it configurable by config.ini to enable/disable usb power on power off/suspend. I will need to test it.
Shouldn’t it be possible to power down / suspend disks through smartctl etc., but keep the USB ports powered? I don’t know how much power disks use in sleep mode though.
You’re right, since I’m an admin I can see everybody, even if they set their profile to Private.
This means that no one else can see them being part of the team on GitHub.
So I have recently purchased an Odroid N2, and installed CoreElec on it. Here is my setup:
Odroid N2 (Running CoreELEC 9.0.1 and Kodi 18.3 *Compiled 2019-07-03)
With the official Plex for Kodi Add-on (Version: 1.16.3.1433)
Player Settings >
Adjust display refresh rate On start/ stop (there is no auto?)
Allow Hardware Acceleration on all formats
System Settings >
Number of Channels 7.1
Passthrough Enabled (all formats enabled)
Plex Settings > Video is set to allow direct play, direct stream, 4k and HEVC.
It is coming from my local Plex server, over gigabit ethernet.
connects
Onkyo TX-NR676 AV Receiver
connects to
Samsung NU8000
I’m having a weird issue though, the video/audio randomly cuts. The Audio goes quite, and the screen goes completely black. It does it just running Kodi alone (not the Plex app at all or anything playing).
I don’t believe its a power issue, as it doesn’t turn off completely… just flickers off/on really quick. I did purchase and try an official power supply though to be certain, and still getting the same problem.
There was one setting I was unsure of… In CoreElec. Go to Settings > CoreELEC.
Tone map SDR to HDR set to Auto
Tone map HDR to SDR set to off
I switched these settings from their default, as I have an HDR capable TV and A/V receiver that can push HDR to the TV.
I don’t believe this is a performance issue with any hardware… I have tried different power supplies and HDMI cables with no luck. If anyone has any suggestions on where to start… that would be very helpful!
Also… I must say. This is the BEST experience I have had thus far trying to play 4K movies in HDR and also allow full Audio Passthrough to my receiver. It has beat everything I have tired (raspberry pi 4, Verok 4k +, and my default Samsung tv apps *which do great for video… but can’t do the audio). So i’m super happy with it this far and understand it is still in testing stages. Just hoping to help workout some bugs possibly and make it even better!
