What you see in the Odroid_N2 folder is the latest version publicly available.
Try sh ./odroidn2toemmc.bash
Is there a list of the remaining problems ? (reported by the community)
No. Everything is in the first/second posts.
Main issues that remain are with some H264 and HEVC encodes.
Yes i am using a brand new Samsung 32 GB EVO Plus MicroSDHC UHS-1
I burned the image with Etcher which checks and Validates the image after the process and safely ejects the sd card.
I use a Mac so no rufus.
Never had issues.
Fresh Install so no gremlins . No backup from previous build used.
Only happens from suspend.
Cold boot no issues.
I don’t have a remote to power it on from off , so can’t test that.
SD Card is inserted properly
delete please
CoreELEC (community): devel-1555398703 (Amlogic-ng.arm)
CoreELEC:~ # cd download
CoreELEC:~/download # sh ./odroidn2toemmc.bash
: not foundoemmc.bash: line 2:
: not foundoemmc.bash: line 5:
: not foundoemmc.bash: line 12:
: not foundoemmc.bash: line 21:
in /proc/mountsd /flash
./odroidn2toemmc.bash: line 127: syntax error: unexpected word (expecting “in”)
Your doing it all wrong, just enter installtoemmc
Okay ,
For the sake of the exercise i installed a different version of Etcher (Balena for Mac) and opened packaging of another brand new Samsung EVO Plus SD Card.
Flashed it.
Same suspend bug as reported.
notification successfully removed storage device coreelec
I will add that after this notification happens after suspend
I switched off TV and switched it on again.
The notification came on again.
Same issue as @kostaman
Got notification about storage being removed after waking up from suspend (via CEC).
Network (wired) completely offline, cannot SSH to it.
Just for the record. Can you verify the Application used to burn the image.
Your SD Card brand and specs.
Exactly same as yours. Samsung EVO plus UHS-1 32Gb.
I used -Win32DiskImager.-
EDIT. Sorry I was using LibreELEC USB-SD Creator
Wtf? This script is included. Don’t download it ;).
Thanks @kostaman. I will try SD card. There seems to be a serious bug that doesn’t affect emmc.
Renamed my script doooh. And I keep telling people about the old name
@afl1 Do you have a build with this fix that you committed? Is it working fully?
https://github.com/CoreELEC/linux-amlogic/commit/0d33ccc124a5ed4c4c36f0a4c12bfe5c79c0f61c?fbclid=IwAR26M6isUMcDuW_lZUHeUpIPv2VJxrXOefND_UZQ3FTAMMgQA3jPBGMti_w
@Ray
Edit: I see that you have included it in the April 14th build. But it does not solve my issue. I do not get DD+ audio at any refresh rate. My setup is N2>Yamaha RXV781 receiver > Hisense 4K.
We are aware of remaining Audio issues. It is not that easy to solve. I for one don’t have an AVR so I leave fixing it to people that do have one.
I think there is something wrong with this Samsung EVO plus SD card. Anyone here with suspend wakeup problems can you please provide:
What N2 Model? 2G or 4G?
What SD card Model? Brand and size.
I can not reproduce this issue with Sandisk card.
I have a spare SanDisk ultra sdhc A1 16gb… I’ll do some test.
N2 is 2Gb version
EDIT.
Can confirm. No suspend issue with this card
Still getting the suspend GUI and other problems from CEC suspend.
N2, 4gb
Samsung Evo plus128gb. Funny thing is I’ve always found this make of card to be the most reliable with other devices.
Tried different flashing software, same result.
Should I try a SanDisk card as I have those too?
