Odroid N2 test builds
  1. Oops, I thought I answered you.
    It has been disabled for a few days now, but the problem is still there.
  2. Are you sure I am an isolated case ?
Your support and the quality of your answers are impressive. Thank you for the job.
Have you tried a clean flash?
I’m chasing down this CEC issue but without uart output it will be hard/impossible.
As for the color banding I don’t see this on my OLED. Can you provide a short sample that has that issue?
A sample. You mean, a video filmed ?
Also @Bindou you say 444 chroma is working?
You can force it my
echo 444,10bit into the attr sysfs
Another idea. I see your IP range is the same as with my FritzBox. I noticed with my laptop what some Ethernet ports use EEE powersaving. This weird ip is when N2 doesn’t get an IP.
You could try to disable powersaving in the router.
Also run:
ethtool eth0|pastebinit
Probably eee is enabled.
I mean a file where the issue shows. Is it HDR or what?
yes i did dmesg is from a clean install on my sd card.
On my emmc i got the same
Ray
Apologies but another IR question.
I’m trying to get power on working but am confused.
ir-keytable -u shows nothing from my remote. Presumably because it’s RC-6 and not NEC. I have however taken the keycode from my rc_keymaps file and used this to update config.ini as follows:
remotewakeup="0xbf40fe01"
decode_type="0x5"
But no joy.
I could not get it to work with RC6. Not sure why. It’s on my todo
Can you check if eee is enabled?
It does that on all films UHD (HDR) or Kodi indicates YUV444 in output.
i have a asus ac68u router and can’t find any eee setting in my router
Well I do understand your frustrations but this doesn’t help me. I need a file and I need to know what to look for and you need to tell me what chroma works.
It should default to 420
I mean in CoreELEC on your N2
ethtool eth0
I can’t find eee in ethtool eth0 too…
Where to look else?
ethtool --show-eee eth0
thanks!
it shows it’s disabled
Hmmh. You are the first to report this issue. Do you have a 2G or 4G ram N2? Also you are sure the cable is right? Tried a different Ethernet port on the router?
Also did you test Hardkernel Ubuntu?
