With bypass_all disabled horizontal line interlace artifacts are added to content marked as interlaced yet not really interlaced. This sample displays fine using software decoder /w deinterlacing disabled and also using hardware decode with bypass_all enabled. ds9p_10.mkv (3.5 MB)
Content both marked interlaced and actually interlaced is deinterlaced yet there are still horizontal line artifacts visible when bypass_all is disabled. ds9i_10.mkv (3.5 MB)
With bypass_all enabled both of the samples above look fine. Horizontal lines are not visible at all and they look great. Yet there are still minor weird things happening. Following sample is marked interlaced yet not interlaced. Notice jagged edges around large orange text. This disappears when bypass_all is disabled and does not show up in software decoder with deinterlace disabled. mb_7.mkv (3.2 MB)
Yes some of my builds have weird experiments. One with GUI improvements introduced av sync issues. The other one with irqbalancer introduced picture jumping back and forth in a loop.
My builds are not recommended to run as daily driver. If those work I merge my code into official CE so you get the good stuff eventually.
You may already know that the AV1 codec is badly managed on N2.
Results of my tests :
Only 480p videos pass. The 720p and 1080p jerks. And the 4K and 8K do not pass at all.
It seems to me that the S922x does not support the AV1. But do you think that it will be possible to obtain interressant performances with the software part ? At least for the 1080p ?
when I use the Zattoo PVR-client, the channel informations are shown at the bottom every 15 seconds for 3 seconds. This behavior is only shown on my Odroid N2. My Odroid C2 does not show this behavior.
(The lastest nightly of “relkai” is installed on the N2)
I have a problem where I can not download subtitles via opensubtitles addon after the CE is iddle for about 5 mins. The dialog will say downloading subtitles and just sits there.
If I restart CE and try to download subtitle - it just work fine. After about 5 mins (screensaver kicks in) I try again and it will stop working completely.
I’m in Australia where opensubtitles website is blocked. To prevent this I use static IP address and have changed DNS server in CE to (google) 8.8.8.8.
PS: Great job in getting CE running on Odroid N2 so fast.
