There something wrong - in the decoder. I see the same here with a 1080p endgame trailer. Looks like the same if bypass_all is enabled!? No problems on 1080i. Looks a problem with the deinterlace.
The enable_switch_fense really makes it even more bad.
Without whitelisting all my used resolutions, my vizio 2015 tv cannot switch to 4k with adjust display refresh rate “on” . It was mentioned here a fix was implemented for this issue. @stillmatic have you witnessed any change with regards to this? If you disable whitelisting, is it still not switching and instead giving a blank screen as before?
This isn’t making any sense.
I was seeing only left hand side.
Note after a few reboots is working fine but only for 25 seconds at a time.
E.g. captures for 25 seconds
Then times out connecting to device for 25 seconds
Just installed latest nightly on brand new N2 and irw can’t scan any codes while ir-keytable stops with
No devices found
I have a95x remote and I though it would be enough to put config file in ./config.
Any documentation regarding this topic?
