morning @Ray i see the 7th may image is still suffering with the live tv dvb-t2 slowdown issue (not rebooted box recently so havent checked latest nightly yet), is there any movement on a resolution for this, other than to disable deinterlace (assuming thats what the line below does). The command below does ‘fix’ the issue, im just not sure if this is THE solution or simply a workaround for now?, one thing i can say is that it does fix the slowdown issue when watching hd live tv.
If it is a workaround only then im happy to do some debug for you if it helps identify a better solution.
Ok cool, thanks Ray, can I assume then that the bypass_all hack will make it into a nightly release or do I need to keep that in the autostart.sh for the foreseeable?
No it won’t because it is personal taste. I do not care about interlaced video. Imo it is something useless from the past. Everyone can decide for themselves what looks better.
i understand what you are saying about personal taste, but for hd live tv it is broken without this fix, so its a bit more than personal taste in regards to deinterlace capability, at least this is true for people who need hd live tv, i accept that is probably a minority of the user base.
in any case, im happy with the workaround, and appreciate the reply ray, i shall carry on with the entry in my autostart.sh
Did someone have an idea why Ubuntu doesn’t boot on sd card with Coreelec on EMMC?
There is a boot.ini present.
I have the Coreelec boot logo on screen and it does nothing?
If I put another testing Corelec it boot well on the sdcard version.
I tried to compare boot.ini but not enough familiar yet.
