Hi ray, here is the dmesg with CEC logging on.
Operations
Tv already on.
Reboot n2
SSH in and enable logging
Restart Kodi.
Wait until Kodi came back up then pressed up and down on remote a few dozen times.
There was no CEC action at all.
I literally did this 3 times before realising the command is echo 1 not 0 to enable logging XD.
3 out of 4 times CEC didn’t work. It did once
libCEC version: 4.0.4, compiled on Tue May 14 23:42:34 UTC 2019 by relkai@hammbwcor01 on Linux 4.15.0-48-generic (x86_64), features: P8_USB, DRM, P8_detect, AOCEC
Found devices: 1
I’m running Windows LTSC 2019 and yes they have in fact fixed the Notepad CR/LF problem. As a test I opened a CoreELEC config file in notepad and saved. Then I did a bit compare to the original file. No difference. So yeah, on the latest version of Windows 10 you can use Notepad without ill effects, finally.
Now tabs can be a different story. I’m perfectly comfortable with vi, literally been using it for decades, but sometimes it’s handy to use Notepad from a share. I haven’t checked Notepad does not mangle tabs created in vi or vice versa so that can still be a problem.
Cool, that blinking light was bothersome. Think you left off part of that command indicating which filesystem to remount, should say “mount -o rw,remount /flash”. Anyway, was able to shut off that blinky light no problem.
If possible, I’d like to make the blue light the power indication and the red light some other useful indication. Don’t know if that’s do-able, but if it is that would be good for me.
I’m having a problem with my remote since the latest build. I have to stop the deamon and reload the ir-keytable to get my remote working after a reboot.
I had 1 cable which is bad with CEC so I threw it away, no problems with CEC on my TV now, it does take a few seconds after starting Kodi to start responding but this was the same on older devices also.
Mine very rarely works after restarting the n2.
Usually have to switch tv input and then switch back to get it to start working.
It usually happens when first turning the tv on after coming home.
Turn tv on. N2 was the last active source so it returns to that. No CEC without changing tv inputs away and back.
I just tested with an eMMC, and I always have the following bug :
N2 does not wake up when I turn on the TV. The CEC works perfectly on all the features, except the wakeful output. It’s like N2 was off, instead of going to sleep.
Specifically, N2 still turns on occasionally, but it’s random. I sometimes have to turn off and turn on my TV 3 to 4 times N2 turns on.
I think the problem of the fact that when N2 is asleep, it no longer sends the signal that lets know that it is present in the chain CEC.
