petiboot is updatet. SPI?
Well itās hard to tell what the issue is. I think for most of us 1G is working.
Do you have 1G speed in Ubuntu or Android? (if you have them on box)
Try different cable, check pins in Ethernet slot, reseat cable⦠should work as 1G
The one you posted with the Hyperion fix.
https://test.coreelec.org/ray/CoreELEC-Amlogic-ng.arm-9.0-devel-1558701842.tar
But it might not be specific to that build.
Havenāt really been keeping an eye out for when it started behaving.
Itās just one of them that when it stops I just change inputs and donāt really think about it.
Edit.
It wouldnāt work again this morning so was false positive
Iām thinking now I shouldāve posted this here, as opposed to itās own topic.
Having remote issue on latest nightly, 21090525. Remote will lock up after a certain amount of time. Kodi needs to be restarted to get it working again. Using a Harmony, set up as MCS. after I restart kodi from ssh, it works fine again. Tried a fresh install on SD, same issue. Since remote doesnāt work, having issue uploading debug log, as I had to restart kodi to get the remote working again, and log file is now kodi.old.log. How do I upload the kodi.old.log file? Thanks!
You donāt need GUI at all to provide logs.
dmesg|paste
paste .kodi/temp/kodi.log
Thanks. Did a fresh install to EMMC. Setup kodi, and started scanning a video library on SMB share on a NAS. Remote stopped responding shortly after. http://ix.io/1K5t. Kodi is still scanning the ligrary, but remote will no answer. Let me know what else you might need. Thanks!
Kodi.log would be helpful. Hardware seems fine.
On 25.05 build kodi service is restarted every 20-30 minutes ⦠TV turns on
May be a silly question but how do I update?
The update is set to auto, I keep getting the notification to say updates are available. Iāve rebooted multiple times and thought thatās when it did the install?
more informations - where is the crashlog?
TV turns on after restart? i down now, the dev just like that⦠(maybe itās due to wrong CEC settings)
Guys com on !!! Gives developers more information
which version is currently installed?
20190508
I was after a confirmation of if the process Iām doing is correct
I have seen this too. You should download a tar and put into .update folder. Older nightlies had a bug where auto update didnāt work.
[quote=āRay, post:1694, topic:4560, full:trueā]
[/quote]
Sorry, thought I uploaded the kodi.log. OK, restarted, started updating music library off SMB nas share. Remote became very unresponsive around 7:28am. Would only take about every 9th keypress. Kodi.log here: http://ix.io/1K7i , I pasted the kodi.log from .kodi/temp/kodi.log, is that correct? Do I need a more specific logging? I also see a crash file, so pasted it here: http://ix.io/1K7j , donāt know if itās related. Thanks!
This is a dmesg/kernel log not kodi log
Sorry, this should be a log: http://ix.io/1K7D
Start update of music library and remotes(harmony as āmedia center PCā and hardkernal) become intermittently very unresponsive till library update is complete or stopped. Keyboard works fine.
Can you post:
cat /proc/interrupts |paste
