system start by remote control not possible.
can you get a cnfg. to adjust? or is it not possible yet?
gbit lan now works !
Please give us more details about how 1 Gb issue was solved?
For Remote wake up:
Also there is a good button
on the top of screen for instructions that contain answers on most popular questions
…at the end of the Config.ini, the output values of the command “ir-keytable -u” must be entered in this formatting (only an example):
remotewakeup=‘0x9b64d880’
decode_type=‘0x0’
remotewakeupmask=‘0xffffffff’
How did you get 1GB Lan working cause it’s still not working for me
Update petitboot.
i did that. but it didn’t working for me
What is the latest sdcard imgae for petitboot in the wiki there is still this image from april.
Hyperion fix is not in the latest nighly build from today, or is it? If it in, it does not work.
It is a backport for the current kernel. Have you used my testbuild?
It is in the 20190525 nightly.
Thank you. I have asked tobetter (HK dev) to help us.
Hyperion is not working in the 20190525 nightly.
It is working.
Thank you!
Thanks Ray.
I can confirm Hyperion is still not working correctly for me, the test build is fine for most of my content, around 75% which is maybe why we are seeing different results, but it does introduces video locking/skipping on certain files.
The 25th nightly does not have the stuttering but re-introduces the previous issue where the screen capture is garbled:
Here is a sample of the file the has the issues if it useful for anyone:
Cheers, E.
How are you guys getting the live preview to work in Hyperion
It never shows anything for me even though Hyperion is working
With your testbuild Hyperion works fine
Look the colors. Nothing ist working
I proto forward from the N2 to a instance of Hyperion running on a separate server then I can have multiple devices forward to that with priorities, when you forward you can see the image on the server which is handy as you get the output of the framegrab but I’ve never seen it locally
@sunnyfunny test build only works partially for me, does display the correct colours but a number of 1080p h264 files have freezing issues, with or without Hyperion running. When I get the garbled output on the 25th nightly and previous builds the colours match the garbled image, they do not skip but the colours are out for me.
Cheers, E.
I just got my Odroid N2 along with the 5a WiFi module and have installed the nightly. I am seeing the network dropping out for about 5 seconds every minute or so. I put in a wireless N USB adaptor and it is not doing this.
Is anyone else seeing this issue?
I talked to tobetter and he said it would be good to report this on their forum. Maybe your device is broken.
