What build are you testing?
We are happy to discuss GT King but please not in this Thread.
after running “ir-keytable -u” and pressing the desired button on my remote (=xboxone-ir), i got:
Received IRMP code: remotewakeup=‘0x9b64d880’, decode_type=‘0x0’, remotewakeupmask='0xffffffff’
What exactly do I have to add now to the config.ini ???
Cheers
Mark
Exactly the 3 variables one for each line. Although decode_type 0 is default so only the 2
@Ray
…so at the end of config.ini in this way?
decode_type='0x0
remotewakeupmask=‘0xffffffff’
Cheers Ray, I know Wifi can be a bit flakey so wanted to wait until I tried wired again today.
Done some more testing and still getting the freezing/skipping, it is with or without Hyperion enabled so think the fixes have taken at that end which is cool!!
It’s a few 1080p h264 files in my library but not all, I’ll try again after the next nightly and see what it is like, I’ve got a sample file ready to upload if it needed.
I’ve attached the log with the error in just in case there is anything in there now and will give it another go when the next nightly is up
journalctl.txt (36.6 KB)
I tried this now, but I don’t get anything in the SSH console window, and also nothing in the dmesg output after using
echo 2 > /sys/module/rc_core/parameters/debug
followed by ir-keytable -u.
EDIT: my STB remote seems to work so I can use that one for resuming.
Drop the “$”
And add a ’ after the 0x0 value. Copy paste error?
Sounds great. Kudos to Portisch for implementing this.
Yes the wake from IR function works great on my N2 even when using full shutdown. Really happy to have that.
hi at the latest odroid image from relkai the language is only english.
It’s always been this way. You can install your language from Kodi repo.
until now it has always been about the setup wizard. not with the image. That’s why I say it.
Nothing changed their since yesterday
ethernet works only with 100MB
It’s time for me to thank the CoreELEC team for their hard work. A lot has been done over the last 7 weeks and I am delighted to see CoreELEC improving day by day on the Odroid N2. Meanwhile, DVB-S2, Zattoo TV, Amazon Video, SkyGo and many other things work really well at my device.
The bonus for me is a well-functioning Xbox one remote control including wake on ir, as well as a nice little OLED display.
Keep it up!
Cheers
Mark
You need to elaborate more. We are here to help. Some people reported that petitboot firmware needs to be updated to get Ethernet at 1G working. Refer to odroid wiki for that.
