Hi Portisch,
I was testing CoreELEC nightly N2 build on Panasonic Plasma and Denon AVR-X2000 - both devices very old and faced problems reported above.
Now I have connected N2 to Panasonic OLED TV and Denon AVR-X2200 - TV is manufactured in 2018, AVR also quite new model and CEC works as it should, except one small issue: once N2 is restarted CEC is “switching on” after around 2-4 seconds and 4 buttons do not respond: Stop, Pause, Next (>>|) and Previous (|<<) but powering off and on TV while HDMI 2 (N2) is active source brings back those buttons functionalities. The same was with Odroid-C2 connected to old Plasma Panasonic and old Denon so I’m pretty sure it’s Panasonic issue.
Now I’m testing CoreELEC on N2 connected to Panasonic OLED TV and Denon AVR-X2200.
Discovered so far:
- No video at all from some 4K files (for instance: Samsung Wonderland Two HDR UHD 4K Demo.ts)
Video
Menu ID : 1 (0x1)
Format : HEVC
Commercial name : HDR10
Format profile : Main 10@L5.1@High
Codec ID : 36
Duration : 2 min 9 s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Writing library : ATEME Titan File 3.7.9 (4.7.9.0)
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0500 cd/m2, max: 1000 cd/m2
while some 4K videos are OK (for instance: Sony Mont Blanc HDR UHD 4K Demo.mp4)
Video
Format                                   : HEVC
Codec ID                                 : hvc1
Codec ID/Info                            : High Efficiency Video Coding
Duration                                 : 1 min 28 s
Bit rate                                 : 71.8 Mb/s
Frame rate mode                          : Constant
Frame rate                               : 50.000 FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.173
Stream size                              : 753 MiB (100%)
Encoded date                             : UTC 2017-01-27 06:42:55
Tagged date                              : UTC 2017-01-27 06:42:55
Mastering display color primaries        : R: x=1.000000 y=1.000000, G: x=1.000000 y=1.000000, B: x=1.000000 y=1.000000, White point: x=1.000000 y=1.000000
Mastering display luminance              : min: 0.1000 cd/m2, max: 1 cd/m2
Codec configuration box                  : hvcC
Distorted (something like in “slow motion”) voice on movies with Advanced Audio Codec
Audio
Format : AAC LC SBR
Format/Info : Advanced Audio Codec Low Complexity with Spectral Band Replication
Commercial name : HE-AAC
Format settings : Explicit
Codec ID : A_AAC-2
Duration : 40 min 42 s
Bit rate : 217 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 23.438 FPS (2048 SPF)
Compression mode : Lossy
Delay relative to video : 23 ms
Stream size : 63.1 MiB (12%)
Language : English
Default : Yes
Forced : No -
No video from SD content:
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings : BVOP2
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1 h 36 min
Bit rate : 1 995 kb/s
Width : 720 pixels
Height : 400 pixels
Original display aspect ratio : 16:9
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.289
Stream size : 1.34 GiB (88%)
Writing library : XviD 64
Before Odroid-N2 I used to use Minix_NEO U9-H running LibreELEC-S912.arm-8.2.4.1.force.444.10bit available on https://github.com/wrxtasy/LibreELEC.tv/releases/tag/8.2.4.1 and there were no problems reported above.
Are those issues known for devs or should I collect some logs for troubleshooting?
