By connecting a USB->UART adapter to the TX\RX\GND pins on your device, or to this CoreELEC Team SDIO Debug Board
thank you very much , i will do that recently.
if the boot progress follow the under order:
1:load BootLoader (uboot);
2:run the uboot script (aml_script)>run cfgload script;
3:load the dtb;
4:load the kernel;
5:load the system…???
need your help.
Help with what?
the boot sequence,is that right?
Just post the full uboot log after turning the box on.
fine,my USB->UART adapter will be arrived in few days,then i will post the log.
here is the log with Android boot:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2021.10.07 23:38:11 =~=~=~=~=~=~=~=~=~=~=~=
GXLX:BL1:9ac50e:4a8da0;FEAT:ADFD318C:0;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0;
TE: 96994
BL2 Built : 14:48:45, Sep 26 2018.
gxl g6d68897 - yao.zhang@droid07
Board ID = 3, adc=226
set vcck to 1070 mv
set vddee to 1070 mv
CPU clk: 1200MHz
DDR3
DDR3 chl: Rank0+1 @ 792MHz - FAIL
DDR3 chl: Rank0 @ 792MHz
bist_test rank: 0 25 00 4b 31 0f 54 25 03 47 35 15 56 26 01 4b 33 12 55 22 00 44 35 14 56 664 - PASS
Rank0: 1024MB(auto)-2T-11
AddrBus test pass!
-s
Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000
New fip structure!
Load bl30 from eMMC, src: 0x00010200, des: 0x013c0000, size: 0x00007600
Load bl301 from eMMC, src: 0x00018200, des: 0x01380000, size: 0x00002200
Load bl31 from eMMC, src: 0x0001c200, des: 0x10100000, size: 0x00019600
Load bl33 from eMMC, src: 0x00038200, des: 0x01000000, size: 0x00047200
NOTICE: BL3-1: v1.0(debug):361f8a7
NOTICE: BL3-1: Built : 16:43:26, Dec 19 2018
NOTICE: BL31: GXL normal boot!
NOTICE: BL31: BL33 decompress pass
[Image: gxl_v1.1.3103-9234004-dirty 2019-04-17 20:46:18 yao.zhang@droid07]
efuse init ops = c1
efuse init hdcp = c, cf9=7
x2_hp_e = 0
bl30: check_permit, count is 1
bl30: check_permit: ok!
chipid: 0 0 3 c c 0 92 b3 98 a0 0 c1 not ES chip
[0.562343 Inits done]
INFO: BL3-1: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader
ERROR: Error initializing runtime service opteed_fast
INFO: BL3-1: Preparing for EL3 exit to normal world
INFO: BL3-1: Next image address = 0x1000000
INFO: BL3-1: Next image spsr = 0x3c9
U-Boot 2015.01 (Jul 25 2020 - 14:24:51)
DRAM: 1 GiB
Relocation Offset is: 36eef000
gpio: pin GPIODV_24 (gpio 43) value is 1
register usb cfg[0][1] = 0000000037f61540
[CANVAS]canvas init
vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters
vpu: clk_level = 7
vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300)
vpp: vpp_init
MMC: aml_priv->desc_buf = 0x0000000033edfac0
aml_priv->desc_buf = 0x0000000033ee1de0
SDIO Port B: 0, SDIO Port C: 1
emmc/sd response timeout, cmd8, status=0x3ff2800
emmc/sd response timeout, cmd55, status=0x3ff2800
[mmc_init] mmc init success
dtb magic 08088b1f
Amlogic multi-dtb tool
GZIP format, decompress...
Multi dtb detected
2layers board, board id use 7
Multi dtb tool version: v2 .
Support 8 dtbs.
aml_dt soc: gxlx platform: p261 variant: 1g
dtb 0 soc: gxl plat: p211 vari: 1g
dtb 1 soc: gxl plat: p211 vari: 2g
dtb 2 soc: gxl plat: p215 vari: 1g
dtb 3 soc: gxl plat: p215 vari: 2g
dtb 4 soc: gxlx plat: p261 vari: 1g
dtb 5 soc: gxlx plat: p261 vari: 2g
dtb 6 soc: gxlx plat: p265 vari: 1g
dtb 7 soc: gxlx plat: p265 vari: 2g
Find match dtb: 4
start dts,buffer=0000000033ee4610,dt_addr=0000000033ee4610
Single dtb detected
parts: 14
00: logo 0000000002000000 1
01: recovery 0000000002000000 1
02: rsv 0000000000800000 1
03: tee 0000000000800000 1
04: crypt 0000000002000000 1
05: misc 0000000002000000 1
06: instaboot 0000000020000000 1
07: boot 0000000002000000 1
08: system 0000000040000000 1
09: cache 0000000020000000 2
10: params 0000000004000000 2
11: bootfiles 0000000020000000 2
12: flashdata 0000000004000000 2
13: data ffffffffffffffff 4
eMMC/TSD partition table have been checked OK!
check pattern success
mmc env offset: 0x27400000
In: serial
Out: serial
Err: serial
board id is : 3
hpd_state=1
[1080p60hz] is invalid for cvbs.
set hdmitx VIC = 16
config HPLL = 2970
HPLL: 0xc000027b
config HPLL done
j = 4 vid_clk_div = 1
hdmitx: set enc for VIC: 16
HDMITX-DWC addr=0x10004006 rd_data=0x40
Error: HDMITX-DWC exp_data=0xff mask=0x9f
hdmitx phy setting done
div40 = 0
hdmtix: set audio
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
_verify_dtb_checksum()-924: calc 3b531134, store 3b531134
dtb_read()-1046: total valid 2
dtb_read()-1113: do nothing
Multi dtb detected
Support 8 dtbs.
Find match dtb: 4
wipe_data=successful
wipe_cache=successful
Err imgread(L340):Logo header err.
There is no valid bmp file at the given address
[OSD]load fb addr from dts
[OSD]failed to get fb addr for logo
[OSD]use default fb_addr parameters
[OSD]fb_addr for logo: 0x3d800000
[CANVAS]addr=0x3d800000 width=3840, height=2160
upgrade_step=2
amlkey_init() enter!
[EFUSE_MSG]keynum is 4
[BL31]: tee size: 0
rebootmode=cold_boot
key1 = 7d82dd22
key2 = 7e81dd22
key3 = 7e81dd22
time_out = 7a120
ir init
irkey - irkey key_value1 key_value2 key_value3 time_value
Usage:
irkey
Hit any key to stop autoboot: 1 0
card out
emmc/sd response timeout, cmd8, status=0x1ff2800
emmc/sd response timeout, cmd55, status=0x1ff2800
emmc/sd response timeout, cmd1, status=0x1ff2800
** Bad device mmc 0 **
(Re)start USB...
USB0: USB3.0 XHCI init start
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
** Bad device usb 0 **
ee_gate_off ...
## Booting Android Image at 0x01080000 ...
reloc_addr =33efbd30
copy done
Single dtb detected
load dtb from 0x1000000 ......
Uncompressing Kernel Image ... OK
kernel loaded at 0x01080000, end = 0x01fb40c0
Loading Ramdisk to 33e02000, end 33edd218 ... OK
Loading Device Tree to 000000000fff3000, end 000000000ffff941 ... OK
signature:
fdt_instaboot: get header err
Starting kernel ...
uboot time: 4015131 us
[ 0.000000@0] Initializing cgroup subsys cpu
[ 0.000000@0] Initializing cgroup subsys cpuacct
[ 0.000000@0] Linux version 3.14.29 (lsmin@jiuzhoutech) (gcc version 4.9.2 20140904 (prerelease) (crosstool-NG linaro-1.13.1-4.9-2014.09 - Linaro GCC 4.9-2014.09) ) #1 SMP PREEMPT Tue May 8 09:51:35 HKT 2018
[ 0.000000@0] CPU: ARMv71 Processor [410fd034] revision 4
[ 0.000000@0] bootconsole [earlycon0] enabled
get_dvfs_info 0007
INFO: HDCP22 key read fail!
INFO: p1d 0
INFO: pd1 0
root@p201_iptv:/ #kodi-support
here is the log with ce9.28 used gxl_p212_1g.dtb:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2021.10.07 23:39:39 =~=~=~=~=~=~=~=~=~=~=~=
[ 83.596027@0] SysRq : Emergency Remount R/O
INFO: PSCI Affinity Map:
INFO: AffInst: Level 0, MPID 0x0, State ON
INFO: AffInst: Level 0, MPID 0x1, State ON
INFO: AffInst: Level 0, MPID 0x2, State ON
INFO: AffInst: Level 0, MPID 0x3, State ON
bl31 reboot reason: 0x1
bl31 reboot reason: 0x3
ERROR: gxbb System Reset: SCP error 2230699255.
TE: 96362
Board ID = 3, adc=227
set vcck to 1070 mv
CPU clk: 1200MHz
DDR3
bist_test rank: 0 25 00 4b 30 0e 52 22 00 44 36 17 55 26 01 4b 35 13 57 22 01 44 34 14 55 664 - PASS
AddrBus test pass!
-s
New fip structure!
efuse init ops = c1
x2_hp_e = 0
[0.561861 Inits done]
DRAM: 1 GiB
[CANVAS]canvas init
vpu: clk_level = 7
vpp: vpp_init
dtb magic 08088b1f
Multi dtb detected
Support 8 dtbs.
Find match dtb: 4
Single dtb detected
parts: 14
In: serial
Out: serial
Err: serial
board id is : 3
hpd_state=1
set hdmitx VIC = 16
config HPLL = 2970
HPLL: 0xc000027b
config HPLL done
div40 = 0
hdmtix: set audio
Multi dtb detected
Support 8 dtbs.
Find match dtb: 4
upgrade_step=2
[BL31]: tee size: 0
rebootmode=update
Enter USB burn
Try connect time out 1001, 1000, 677
card out
[MSG]mmcinfo failed!
(Re)start USB...
USB XHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
scanning usb for storage devices... init_part() 278: PART_TYPE_DOS
1 Storage Device(s) found
reading aml_autoscript
795 bytes read in 23 ms (33.2 KiB/s)
## Executing script at 01080000
## defenv_reserve
Saving Environment to aml-storage...
Writing to MMC(1)... done
amlkey_init() 70: already init!
[BL31]: tee size: 0
(Re)start USB...
USB XHCI 1.00
reading kernel.img
12318720 bytes read in 6445 ms (1.8 MiB/s)
reading dtb.img
40792 bytes read in 43 ms (925.8 KiB/s)
ee_gate_off ...
reloc_addr =33ef7650
copy done
Single dtb detected
kernel loaded at 0x01080000, end = 0x01ddd460
Loading Ramdisk to 3397e000, end 33edbe00 ... OK
Loading Device Tree to 000000000fff3000, end 000000000fffff57 ... OK
signature:
Starting kernel ...
uboot time: 13751908 us
[ 0.000000@0] Initializing cgroup subsys cpuset
[ 0.000000@0] Linux version 3.14.29 (portisch@ubuntu) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #1 SMP Tue Sep 7 08:30:05 CEST 2021
[ 0.000000@0] CPU: AArch64 Processor [410fd034] revision 4
[ 0.000000@0] no prop version_code
[ 0.000000@0] CoreELEC dt-id: gxl_p212_1g
[ 0.000000@0] Machine model: Amlogic
[ 0.000000@0] Reserved memory: incorrect alignment of CMA region
[ 0.000000@0] vout_serve: set_vout_init_vmode: 1080p60hz
get_dvfs_info 0007
…stoped here…
The log shows it’s p261, 1g RAM. Not p212
how can i get p261?
help me to add the p261 supports,thank you!
There is no source from Amlogic:
You can ask your vendor for the source DTS files.
i just replace the dtb from android img, and you can see ti is a multi-dtb,here is the log:
start USB...
USB XHCI 1.00
reading kernel.img
12318720 bytes read in 6444 ms (1.8 MiB/s)
reading dtb.img
79885 bytes read in 64 ms (1.2 MiB/s)
ee_gate_off ...
reloc_addr =33efbd70
copy done
Multi dtb detected
Support 8 dtbs.
Find match dtb: 4
Loading Ramdisk to 3397f000, end 33edce00 ... OK
signature:
Starting kernel ...
uboot time: 11136311 us
get_dvfs_info 0007
p200_1g:
uboot time: 11127589 us
[ 0.000000@0] CoreELEC dt-id: gxbb_p200_1G_100M_RealtekWiFi
get_dvfs_info 0007
p281_1G:
uboot time: 11127250 us
[ 0.000000@0] CoreELEC dt-id: gxl_p281_1g
[ 0.000000@0] Reserved memory: unable to setup CMA region
get_dvfs_info 0007
Please use preformated text because it is really hard to read like it is now.
that’s all right,thank you!
what is that mean?
