ok, thanks for you time
You can also try to force resolutions
execute this command
cat /sys/class/amhdmitx/amhdmitx0/disp_cap > /storage/.kodi/userdata/disp_cap
on working display and after try to connect to non-working tv to check if you receive a picture.
I don’t believe it, now don’t work any device that connects to the port hdmi of my tv lg 4k …
And if I leave some device connected to any HDMI port, the TV is constantly rebooting…
Looks like TV issue.
May be you need to reset it to default settings or left without power for some time… Just assumption
OK contact LG support…
yes, I tried this and nothing, dont work…
I have to change the mainboard of my TV…
