Reboot to CoreELEC APK
No problem with windisk is fine to use
The ā€œDune HD Homatics Box R 4K Plusā€ has two USB ports: one USB 2.0 and one USB 3.0
I was connecting the external HDD with the MEDIAs/VIDEOs… to the USB 3.0 port.
And connecting the USB Flash Drive with the CoreELEC to the USB 2.0 port.
It didn’t work with any BOOT method.
Now I connected the USB Flash Drive with the CoreELEC to the USB 3.0 and used the ā€œReboot to CoreELECā€ and it worked!
But there is a problem: the remote control of the ā€œDune HD Homatics Box R 4K Plusā€ did not work.
I’m stuck at the initial CoreELEC configuration screen.
Plug in a usb wireless mouse/keyboard in the other usb port
Or an old usb wired mouse
Try your TV remote maybe recognize CeC
But the ā€œDune HD Homatics Box R 4K Plusā€ is stuck on the CoreELEC setup splash screen.
Can I turn off ā€œDune HD Homatics Box R 4K Plusā€ by disconnecting the PSU?
I don’t have a mouse/keyboard to use right now.
I was able to use a wireless keyboard with touchpad.
Although the keys don’t work correctly (sometimes I press a letter and another one appears), I managed to do the initial configuration of CoreELEC using the touchpad and the keyboard arrows (UP, DOWN, LEFT, RIGHT).
I was able to connect the bluetooth remote control of the ā€œDune HD Homatics Box R 4K Plusā€ by pairing it in the CoreELEC settings.
This app is a Godsend. Didn’t have to bother using the toothpick method to run CE.
