I bought a cheap “broken” gtking box wich I repaired, this box had a 512gb EmuELEC card wich was not working and a 8gb CoreELEC card
Well with the 8gb card inserted the box always boots into Android, and then you have an apk wich reboots the box to the microsd
Well, I downloaded the last CoreELEC 21.0 image and flashed it to the 8gb card (It had CoreELEC 19 originaly instaled). After that the box work as any other box, always boots from microsd if it is inserted.
So that been said I think you can make some configurations in the microsd to force android to boot always first and ignore the SO in to the sd
It is an interesting option, at least for me, so you can always boot to android and then go to CoreELEC as if it was the kodi apk but with the power of CoreELEC
@anon95383068 Do you have a complied version of the 1st or 2nd version of the app? I was looking for the early version that only issues the ‘reboot update’ command when clicking on the homescreen icon, without any jump screen or other dialogue.
Hi.
I have a “Dune HD Homatics Box R 4K Plus” and I’m trying to install CoreELEC using “Reboot to CoreELEC”.
I installed the APK and when I run it, the message “Enable USB debugging first in the developer options” appears.
How do I do this?
Boot the device using the reset button method
If the reset button method doesn’t work:
Try the Android APK Reboot to CoreELEC coreelec:homatics [CoreELEC Wiki]
First appears: Fastboot Press RESET again to enter Recovery mode.
I do nothing, then appears: Usb Burning Mode
I do nothing, and then appears the Android Recovery
I keep the reset button pressed for minutes and nothing happens.
When I release the reset button, in “Android Recovery”, it enters Android TV normally.
Try a different device tree and make sure it is renamed to “dtb.img”. If you have the wrong device tree, this is what happens. Sometimes they change the innards, and the regular device tree does not work. Just a thought.
