I use nfs sometime video is lag
If you have lag experience something it’s wrong.
Nfs it’s far away from smb shares.
I’m using nfs for years without lag.
Forget wi-fi. Use only Lan.
Review your settings on nfs server like maximum NFS transfer size or threats.
Use advanced settings XML
Do you have an example to setting xml?
Hi guys, could someone compare picture quality with s922x boxes (like n2 and gt king) ?
Is 922x better?
First post
For the first time I’ve used coreelec, I don’t know what to do advancedsettings.xml Where to put it,Thank you.
Just put in /userdata and reboot.
Advanced settings can deal with several things (extra configs).
One of that things it’s increase cache using memory of the box to avoid stop buffering etc.
In my advanced settings. XML using 500mb of the memory box:
524288000
Using option 1 in buffer mode to Buffer all filesystems, both internet and local:
1
Option 5 on readfactor:
5
You can read all here to understand better what I’m saying
Thank you so much.
BOX x96air P2 4/32G 1Gbit Lan
DTB sm1_s905x3_4g_1gbit.dtb
Everything work. I did not test yet, 5Ghz wifi, VDF.
CEC work tv hisense b7100
Lan speed did not pass approx 40MB/s, speed of disk cap gigabit lan. I will try to test with iperf.
Had a Crashed when skiping around on video files with 2160p Hevc Hdr trhd.
Anyone instaled coreelec to internal box disk (emmc)?
BOX x96air P2 4/64G 1Gbit LAN
NIGHTLY 20200103
Installed on SD card
Not yet.
Maybe when exist stable version.
SD runs on acceptable speed
Before to playing with the emmc try to find your firmware and to recovery it from a sd.
Try a fast USB 3.0, Sandisk Extreme Pro, they are not far away from emmc.
Do you think a decent flash drive would be better suited than say an A1, V30 micro-sd card?
Maybe or maybe not, it depends on the card and the drive, but USB 3.0 interface is faster than de microSD card reader of this boards. I’ve tested it.
Given the fact that a Sandisk Extreme Pro USB drive may cost someone much more then one of these x96 device do. It might be a better Idea for the average person to try a more reasonably priced, but still reasonable performance ‘Sandisk Ultra Flair’ or ‘Sandisk Ultra Luxe’ first.
I’ll give it a try. I’m.sure I have a flash drive laying around.
Everything working even Bluetooth, 2.4Ghz and 5Ghz wireless.
Build: CoreELEC-Amlogic-ng.arm-9.2-nightly_20200103-Generic
If remote do not wake from suspended, some tvs has an option to wake up from sleep a CEC device.
Try Remote acess VNC using macos screen sharing client, but only trash appears on screen.
My Iperf3 results:
For anyone interested my sd card i use:
Thank you @Rootz for compiling all the infomation an making it available in this post.
Thanks to Coreelec team for making this available and the forum community.
It is a functional box for 30€. Now waiting for stable version to install on emmc. I saw a firmware of this box on freaktab forum, i do not know if is a good idea to try that firmware.
From where can you buy this P2 version for 30€ ?
Bought here
Ship from Spain. Only 4 days to my home
