Great news !
I think it can only do 8K at 30fps
Here’s the first test build based on the latest code we have
https://test.coreelec.org/arthur/CoreELEC-Amlogic-ng.arm-9.1-devel-1562454318-Generic.img.gz
Use nightly.
Installation procedure is just like any Android TV box. Burn SD/USB, place the beelink DTB from the device_trees folder into root and rename it to dtb.img. Put the SD/USB in the box, press and hold the reset button (it’s on the bottom, need something really small, like a SIM ejector), turn the box on, and hold for ~10 seconds.
Things that work:
- PCM audio
- 4K HW decoded H264, HEVC, VP9
- 8K HW decoded HEVC, VP9 - could potentially be buggy.
- WiFi
- Bluetooth
Things that don’t work:
- Audio passthrough
- This build doesn’t include DVB drivers.
- Ethernet can have issues at 1Gbit speed.
In case of Ethernet problems, you can set it to 100Mbps manually. Run the following commands in SSH:
echo "ethtool -s eth0 speed 100 duplex full" >> /storage/.config/autostart.sh
wow nice info thx for sharing
Just been doing some quick testing. I have the newer revision GT King with serial number starting B922. This one has a default CPU speed of 2.2ghz instead of 1.8ghz.
I have not seen any issues with my Ethernet and no buffering even on large 4k files.
wifi appears to be very slow when connecting to my NAS with SMB but not tried NFS yet. Wifi basically unusable for me.
I get screen corruption with 4k HEVC HDR files. The file still plays but has lines over this image and corruption along the bottom. You can still see what is playing.
standard h264 files appear to be ok.
I would say this is great progress so far for a first test build. Thanks for supporting this device.
Please run dmesg | paste and dispinfo in SSH while playing the problematic files and post the URLs.
Here is the info you requested.
http://ix.io/1NUH
http://ix.io/1NUI
The screen overlay does not work either when there is corruption.
Stop the video. Put this in SSH:
echo 444,10bit > /sys/devices/virtual/amhdmitx/amhdmitx0/attr
Then play the video again, see if there’s any difference. If that doesn’t help, try with
echo 422,10bit > /sys/devices/virtual/amhdmitx/amhdmitx0/attr
or
echo 420,10bit > /sys/devices/virtual/amhdmitx/amhdmitx0/attr
Reboot to go back to “normal”.
None of the changes made any difference and with the last change I get a blank screen.
I have now tested the box on 2 tv’s that are both 4k 10bit panels and still get the same corruption. It appears to be the OSD overlay as once the file is playing I cannot get back to any of the menus or bring up the settings until the file is stopped.
I am using this dubai sample file to test - https://www.demolandia.net/downloads.html?id=60876578
HEVC 10-bit 23.976fps
Interesting. I’ve only used it with my old Toshiba LCD TV. I’ll be hooking it up to my LG soon to do some more tests.
Great to see the first public beta ! thanks you all for your work !
I’m testing it.
No ethernet problem for me.
I can’t display kodi in 3840x2160p, the image is stuck and weird.
It works fine in 1920x1080p.
Do you mean GUI or video playback?
GUI, didn’t test playback yet.
Please explain what you mean by “stuck and weird”. Are you using a clean install or did you restore an old backup?
I’m guessing someone restored a backup without removing overscan settings from guisettings.xml.
There is a reason that we recommend fresh installs when changing devices.
I can also confirm no being able to change the GUI to 3840x2160p. I get the same corruption that i see when playing HEVC 10-bit 23.976fps files.
@jza, try commands I sent you in PM early
No restoration at all, its a fresh install. I just try to change GUI resolution to UHD.
The image is corrupted, very difficult to describe it.
