Must be your audio settings. Make sure you set it to 2.0 channels.
Many thanks, that was the problem. Is working perfect now.
Great!
Are the 8K 60FPS videos playing well for you? On my device I had issues.
With today’s Nightly finally I’ve got gigabit:
Summary
CoreELEC:~ # iperf3 -c 192.168.2.2 -R
Connecting to host 192.168.2.2, port 5201
Reverse mode, remote host 192.168.2.2 is sending
[ 5] local 192.168.2.3 port 43442 connected to 192.168.2.2 port 5201
[ ID] Interval Transfer Bitrate
[ 5] 0.00-1.00 sec 112 MBytes 935 Mbits/sec
[ 5] 1.00-2.00 sec 112 MBytes 936 Mbits/sec
[ 5] 2.00-3.00 sec 111 MBytes 934 Mbits/sec
[ 5] 3.00-4.00 sec 112 MBytes 940 Mbits/sec
[ 5] 4.00-5.00 sec 112 MBytes 937 Mbits/sec
[ 5] 5.00-6.00 sec 112 MBytes 940 Mbits/sec
[ 5] 6.00-7.00 sec 112 MBytes 940 Mbits/sec
[ 5] 7.00-8.00 sec 112 MBytes 940 Mbits/sec
[ 5] 8.00-9.00 sec 112 MBytes 938 Mbits/sec
[ 5] 9.00-10.00 sec 111 MBytes 930 Mbits/sec
[ 5] 0.00-10.00 sec 1.09 GBytes 939 Mbits/sec sender
[ 5] 0.00-10.00 sec 1.09 GBytes 937 Mbits/sec receiver
Huh? Strange
On Android always had gigabit, so I think it was a CE (maybe dtb) issue. I don"t know.
OK, something strange with this device with CE,
Summary
[ 5] local 192.168.2.3 port 53958 connected to 192.168.2.2 port 5201
[ 5] 0.00-1.00 sec 30.4 MBytes 255 Mbits/sec
[ 5] 1.00-2.00 sec 28.3 MBytes 238 Mbits/sec
[ 5] 2.00-3.00 sec 32.5 MBytes 273 Mbits/sec
[ 5] 3.00-4.00 sec 29.4 MBytes 247 Mbits/sec
[ 5] 4.00-5.00 sec 32.2 MBytes 270 Mbits/sec
[ 5] 5.00-6.00 sec 32.1 MBytes 269 Mbits/sec
[ 5] 6.00-7.00 sec 29.7 MBytes 250 Mbits/sec
[ 5] 7.00-8.00 sec 34.6 MBytes 291 Mbits/sec
[ 5] 8.00-9.00 sec 33.1 MBytes 277 Mbits/sec
[ 5] 9.00-10.00 sec 36.4 MBytes 305 Mbits/sec
[ 5] 0.00-10.00 sec 319 MBytes 268 Mbits/sec sender
[ 5] 0.00-10.00 sec 319 MBytes 267 Mbits/sec receiver
Just wanted to give some info to those with ethernet troubles, about an experience I had in the past with Mecool devices (not Beelink but problem might be more widespread).
Very surprisingly, the ethernet connection quality was dependent on the BRAND of router. My device had good connection when connected to Asus and Netgear, bad connection when connected to Linksys and TP Link.
Just saying for those with ethernet problems to try different router brands if that makes a difference.
You may be right that some routers may work better with some equipment than others, but I think that it’s crazy to ask someone to replace their router just because a single device is having issues with it.
It’s a problem with the device, not the router.
I agree and N2 doesn’t seem to have any issues. And supposedly they use the same chip.
I think there ist a mode change problem or graphic chip reset problem. The 8k 60 frames plays smoothly and fine without stacking if I do not play a lower resolution before and afterwards. If I had played a lower resolution in the meantime and then the 8k Video stacks or shows only pixel mix without any picture. 4k Videos are playing fine all times. Only after reboot then the device plays the 8k 30/60 videos fine again. Sorry for my bad english.
For me with 1Gbit box is almost unresponsive with Asus and Huawei routers… It possible that it was some defect in early boxes.
As boot2k3 said it was tested in multiple routers. I’m still trying to break mine (for testing purposes) that has, at the moment, gb ethernet.
Do you know why CE doesn’t boot in full HD if android display setting is 4K ?
Both resolutions seems correlated in boot, if android is in 4K and CE in 4K CE boots.
If you are on last TheCoolest image, than try today nightly image.
thanks, I’m using your workaround and the last nightly (0710) and I’m unable to reproduce this issue.
Hello, i have tried mount emby server on this box.
First, installed it over docker and i get this error: docker: Error response from daemon: unable to find “net_prio” in controller set: unknown.
Then, i have installed emby4 addon (the installation is correct) and i can not access by web (ip:8096).
Anything to try?
Until now I am still confused, and I have downloaded the nightly version of CE. Which question is my dtb for my GTK?
Check the device_trees folder on the card and I’m sure you will figure out which dtb is yours.
Saya sudah banyak mencoba dari device_trees, tapi selalu gagal boot. Bisakah anda beri tahu saya yang mana untuk merubah menjadi dtb ?
