I am no longer able to power on the GT King from the remote control since using the test/nightly images. I have to pull the power and reset it again to power on.
I am guessing its something to do with the remote working off a USB dongle as opposed to an internal infrared reader.
I have not added a remote.conf as the device just seemed to work so must be using the meson-ir. I am also unable to power off using the remote button. I have to select poweroff from the main kodi menu.
The remote if RF, you need to connect the small USB dongle to the GT-K. I’ve noticed it’s range is really short, and it’s having problems even from a 2m distance.
Only the power button on the remote is IR.
for images and audio, it’s very good. thank you to all the teams who have worked hard. you guys are great. now i can play dolby atmos and dts hd master. and also 4K films.
It’s important to report all the “bugs” you find. That’s the only way to have a stable image. But I can tell you that it’s pretty stable right now. I’m using it as daily driver mainly for tvheadend client, Netflix and HBO addon.
