In android was ask on network prefix length, when i set default value: 24. This value is not missing in Coreelec ? I see now value for rx packets as 0 in ifconfig. @anon88919003 ?
Did you check if it’s enabled in CE settings?
Yes, it was from boot in socket, was enabled eth0. After connecting on fake ip 169.x.x.x. i disconnected this lan through this setting from fake connections and only after it started wlan for possibility of commanding through ssh from pc.
You are wrong, it´s no fake IP - maybe You have to learn a little bit
It is fake ip, for fail state. But is true, to the really fake ip is, when i set static ip on this tvbox through coreelec, which show this tvbox as connected, but in reality is not going internet/wokgroup/connection on router.
No.
You are wrong and You have no idea about network.
I am not IT and i am only experienced user in this field. I might call ip as post adress
I dont see big disparities
I am IT and cisco certified, You can believe me, or not
Ok, but i have problem with no internet through eth0 than many people with box based on eth0 rtl8211 F. Please use energy on this, please. Gigabit LAN driver problem
It is relevant, or it was builded this patch ? Please check it mr. @anon88919003 https://patchwork.ozlabs.org/project/netdev/cover/20171202220650.23391-1-martin.blumenstingl@googlemail.com/
I am sorry, I do not see any error on CE side and as it looks like you are the only one having issues it’s maybe a fault on your side, sorry. No idea where to look into more further.
OK, thx. I tried also everything. I have KI pro on emmc yet long time withou issue, …on my side is not problem. It must be in driver or coreelec configuration.
I tried yet change static ip adress of tvbox. My router see this new ip adress on my device tvbox, but not going internet on tvbox still and not going also ssh through lan. I tried also command for changing 1000 to 100 full duplex through command: ethtool -s eth0 speed 100 duplex full. After was going internet through DHCP on LAN. In next restart of this tvbox i see again as 1gigabit ethertnet and again not going internet. It need fix for gigabit ethernet on this tvbox from @TheCoolest . Same as in case: Gigabit LAN driver problem After command -s eth0 speed 100 duplex full was text from lshw: *-network:1
description: Ethernet interface
physical id: 4
logical name: eth0
serial: 02:00:00:0c:2a:01
capacity: 1Gbit/s
capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=st_gmac driverversion=Jan_2016 duplex=full ip=192.168.1.131 link=yes multicast=yes port=MII speed=100Mbit/s
Really ?
You are the only one having this issue.
Yes, but this “only” is not solved https://patchwork.ozlabs.org/project/netdev/cover/20171202220650.23391-1-martin.blumenstingl@googlemail.com/ . How you are sure, that only i ? You @Tim_Taylor must more read this forum! @Portisch, please check this output from ssh and please try prepare dtb file, if you have new idea, because without manually ssh command (ethtool -s eth0 speed 100 duplex full) not going ethernet in any mode:
CoreELEC:~ # ethtool eth0
Settings for eth0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 100baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Half 1000baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 100Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Transceiver: external
Auto-negotiation: on
Supports Wake-on: ug
Wake-on: d
Current message level: 0x0000003f (63)
drv probe link timer ifdown ifup
Link detected: yes
What do you want to archive by defining the “-c” parameter?
With ping -c <count> you just configure the number of ping packets being send to the destination.
It has nothing to do with 100/1000 Mbit/s.
The Beelink GT-King used to have the same issue, they fixed something in a firmware update which resolved the problem.
We could never figure out what the actual issue was to solve it on our side.
Ok, but in android is going as 1gbit. Only in Coreelec is not going. I need now yet temporaly solution through dbt through set 100mbit, because is not going internet after restart of tvbox. I am not thinking, that will be realised new firmware (i had from april 2020, which was worst than from february 2020). This issue is impacted with this messages from 2017? In coreelec is used old driver from january 2016. https://patchwork.ozlabs.org/project/netdev/cover/20171202220650.23391-1-martin.blumenstingl@googlemail.com/
Ok, thx. I tried only what i found on forum
