Try this build
https://test.coreelec.org/arthur/CoreELEC-Amlogic-ng.arm-9.2-devel-1592651762.tar
Thank you, i tried this build, but i dont see difference. LAN internet going only after command: ethtool -s eth0 speed 100 duplex full
The previous build had an issue. Please try this one
https://test.coreelec.org/arthur/CoreELEC-Amlogic-ng.arm-9.2-devel-1592656585.tar
And if it still doesn’t work, try the DTB from this post:
If the above build doesn’t work, try this one. Use original DTB from this build.
https://test.coreelec.org/arthur/CoreELEC-Amlogic-ng.arm-9.2-devel-1592657993.tar
ok, i must try also this because above testing was not success. DTB i will let automatically update through update on start.
Again not success with full speed. Only start lan internet after: ethtool -s eth0 speed 100 duplex full
Ok, then I don’t know what we can do on our side.
When is wirelees internet, near star of ip adress is globe. In case of lan is not, if is lan going on 100 mbit mode. This globe means something (acess to outdoor internet) although is going ? It would be set mode 100 mbit from start through dbt ? It is better as nothing lan internet.
You can add the ethtool
command in autostart.sh
isn’t it a router/cable length thing? That it only works with lesser speed. And with x88 king, a connection of the network socket had been disabled. So, one wire of the utp cable was disabled of it’s function in i think the dtb file. Otherways it wouldn’t work with the older x88 king. Maybe the newer ones need this enabled.
on second device KI PRO with 1gbit was/is not problem through coreelec on same cable, and on android with this device x88 king is going also 1gbit. Hardware/cabel problem is excluded. On router i see also profile of speed for all connected devices. It would be impacted that in android have this box 2 ip adress through dhcp? (ip4 and ip6)
thank you, command in autostart.sh is good temporaly solution for me. In next time i will check changes and wait on solutions. Autostart.sh have negative disparity, that is not internet after suspend of device.
You need to report this problem to whoever makes the device. It’s most likely a similar firmware problem that Beelink used to have in the beginning with their GT-King devices.
It would possible add recall to autostart.sh after wakeup from suspend ? It is very useful also for regulation of rotation speed of external HDD and etc. This function of wakeup is not now, what i know.
You can call commands on suspend and on resume: https://libreelec.wiki/creating_suspend_and_resume_scripts
yes, thank you.
Maybe it will be useful. I tried firmware 31.10.2019 r1, but it was for me without functional wlan and lan.
Why ? It was very buggy
