Strange behaver after Update minix u22-xj
Are there any users that have the following problem on the minix u22-xj
After the last update of Coreelec (August), Coreelec no longer worked properly,
Only half of the skin is loaded as if files are missing.
Then I tried a new installation and install a backup.
But now it works slower and not all addons work properly as personal lists via an account tv addons will no longer load.
Or watchlist of trakt.tv is empty while I am sure it is not
Tried to delete the cache by indigo addon but then I get an error
TV add-ons is used for piracy content so no support is given. You have to try a clean install of CoreELEC 9.2.4.2 and if there’s a problem please post your logs.
It is an legal addon! (vtm go)
Not everything is piracy on kodi :wink:
If there is no other option I will try new setup but I hope it is possible to fix because it is a lot of work…
I don’t now where I can find the logs
As long as you have any illegal addon, trakt.tv in your case, no help can be offered.
After cleaning your system from illegal stuff, post a FULL debug log if you need further assistance.
Normal logs are stored in /storage/.kodi/temp
Trakt.tv illegal? so that’s new
If not, pardon my french :wink:
Of course not everything is piracy in kodi, you don’t need to tell me that. So, post your current logs and you’ll receive the support you need:
You do a clean install
Then supply logs
Or
I will mark this thread as solved due to rogue addons.
The one i have quoted you on is responsible for all
previous members issues who had this addon installed.
Google it.
Indigo is a nasty malware addon which you would be best advised to avoid anyway.
Well, my teammates pointed you @Tom31to the right direction. I asked for your current logs and I knew they couldn’t be clean. Indigo is ilegal, TVaddons Repository is banned also. Here’s a list from kodi wiki:
https://kodi.wiki/view/Official:Forum_rules/Banned_add-ons
Seconding kostaman and Shoog on this. The Indigo addon causes a lot of issues. Please get rid of it.
