Sundtek Media TV addon
Hi guys,
I would like to pick up the discuassion again which was started over at the LibreELEC forum back in November last year. The situation we discoverd there still persists, but I may have some additional pertinent information.
Meanwhile, I have Armbian running with the 3.14.29 kernel on my 905W box:
uname -a
Linux amlemby 3.14.29 #131 SMP PREEMPT Wed May 16 16:14:24 MSK 2018 aarch64 aarch64 aarch64 GNU/Linux
On this box, I installed the Sundtek driver in the usual fashion using their netinstall-script. after that, I find:
/opt/bin/mediaclient --arch
Architecture: arm64
However, with CoreELEC on the box I find:
mediaclient --arch
Architecture: armsysvhf
I am pretty sure that this is the problem. Also, @Ray had already provided a tvheadend version for kszaq’s LibreELEC which worked with the Sundtek sticks.
It would really be great if you could provide a stable solution to this, since these sticks are really first rate and I would hate not to be able to use them with your otherwise really great piece of SW!
EDIT: on the other hand, if I replace the tvheadend addon provided in the repos with the one I got from @Ray way back then, it works - so maybe it is not a driver problem on the Sundtek side? I am a bit flustered.
Anyway, it is great to be able to watch Sky UHD football with these boxes - this does not work with kszaq’s LibreELEC, where I only get a black screen. With CoreELEC 8.90.5, however, it seems to work like a charm (at least for the last five minutes …) :+1:
Cheers,
chessplayer
Push …
Just wondering whether there is any progress? Have the sundtek guys responded to your slack invitation, @Ray ?
I think raybuntu isn’t part of ce anymore he never reply anymore
Well, over at kodinerds he said that he had passed on the issue to @afl1 and he had contacted @sundtek (obviously not a user here …) to get in contact with him. That was 3 weeks ago, however, … Also, he at least seems to be reading what is going on here.
R U sure about this? The reason I asked is because there is no mediclient program on my CE box.
#                   CoreELEC
#               https://coreelec.org
CoreELEC (official): 8.95.0 (S912.arm)
CoreELEC:~ # mediaclient --arch
-sh: mediaclient: not found
CoreELEC:~ #
Hi @Habibie, of course, you will have to install the Sundtek Media TV Addon first
Lol, sounds like Fake News :smiley:
:joy: sorry mate
I also have this issue with the Sundtek.
However, I could not get it work with CE.
@chessplayer: Could you send me the tvheadend or driver (or both) which works for you ?
I would reeaaaly really appreciate it.
Sundtek is indeed one of the best tuners and it’s a pity not to have it working, especially that it worked in the past :frowning:
without any waranty or support, here is a link to the TVH-Build I was using with the Sundteks on the China Boxes: https://drive.google.com/open?id=1NMPTfS224oesyb_KGIpkRSVyb0yLNre9
Good luck with that!
chessplayer
Thanks @chessplayer.
It looks like I am not getting any more the DTV_CLEAR failed (e=success) error with this one.
Currently it’s scanning the muxes, will report back if it works!!
Actually, if you see both Tuners listed (i.e., DVB-T and DVB-C), you should be fine. So, if it is scanning the muxes already, this is going to work!
Just remember to turn off automatic updates and NEVER update the TVH-addon (at least not until the one they ship with CE also supports Sundtek).
Actually I have the dvb-s2 tuner, but It has the same driver
For now I have limited success, as all muxes are failed on all satellites. What’s interesting is that it actually moves the dish (I have an H-H motor) , therefore it communicates via Diseq. Will check the cables again, but I have a dual LNB for anorher room, this is how I was able to test that the dish is moved to the right position…
Sorry to hear that. Unfortunately, I can’t say anything about DVB-S, since I have no experience with it.
No problem, you already helped me out by providing this package.
BTW, I’ve opened a different thread, and it seems that sundtek responded.
I hope we can sort this out and the tuners will be supported in official releases.
I think I’ve found the root cause:
https://www.linuxtv.org/pipermail/linux-dvb/2012-May/032921.html
The command that fails is the one listed here, and indeed, the mediasrv is a 32 bit application while the kernel is 64 bit.
So hopefully someone will be able to fix it now.
While that would be wonderful, this 32/64 mixup has been known to be the source of the problem for a while but no one at Sundtek could be bothered to take a look
32/64bit LinuxTV ABI specification bug is discussed there, and should be fixed already.
