I dont know, it should have it. The box is sold as 1G ethernet
I believe the X96 max S905x2 boxes are 100m ethernet for the 2GB/16GB boxes and 1GB ethernet for the 4GB/32GB and 4GB/64GB boxes - that is the latest I can find. I have just bought the 4GB/32GB model and waiting for it to come before installing CE on it.
I made 1Gbit change for 4GB version, but it doesn’t work.
Ok, we will check later. Something more need to be changed.
On Beelink GT1 mini 4/32 GB ethernet works.
I have Beelink GT1 mini 2/32 with 905x2. the coreelec will work? what file img.gz to use? Thank you for answer.
Boot from USB and not from card slot.
You can use a SD card to USB adapter or maybe a USB stick.
i have try o mine USB stick no luck
Perfect, so boot correctly. In my case, wifi does not work either. The wifi of my box is: RTL8822
mi bad as using rong image, boot ok using usb stik, and ethernet is working, ram 4g ok, wifi ins´t, comand powers down ok, but don´t powers on de device
Hi all
I have X96 Max 4/64
Tested with generic img , dtb s905x2 with usb stick but no boot
zambu man : using rong image ?
what is correct img ?
x96 max 4/64
Boot from usb 3.0
ethernet ok
wifi no ok
bluettoth no ok
4 gigas ram detected.
Great step devs.
I dont know what vfd.conf can try for display @TheCoolest
Good, after doing tests in my tanix tx5 max (4/32) I can say that this build is going incredibly well, being the first. In principle, I leave these reports.
Boot SD: Not working
Boot USB (Pendrive): Working
Gigabit Ethernet: Working.
Vdf (FD628): Not working
Remote (meson-ir): Working
HEVC 1080p: Working
H264 1080p: Working
Audio: Working
USBs 3.0 and 2.0: Working
4 GB Ram: Working with the thread dtb
Wifi and Bluetooth (RTL8822): Not Working
I need to try 4k both HEVC and H264.
Mecool KM9 PRO 4GB/32GB
Boot USB 2.0/3.0 (Pendrive): Working
Ethernet: Working.
4 GB Ram: Not working with the thread dtb. showing only 2GB
Wifi and Bluetooth: Not Working
where’s the reset button?
its generic whith dtb post by boot2k3
av hole, back side
I need the android dtb.
To help Devs with adding WiFi/BT support, these are the modules in some popular boxes.
Mecool KM9 PRO - AP6236
X96 Max/A95X Max/MECOOL KM3 - AP6356S
Beelink GT1 Mini/X2 CUBE/T95Q/Mecool KM9 - AP6255
Tanix TX5 Max - FN-Link 6222B-SRB
Sorry for bothering you, I could also see the tanix tx5 max:
DTB:DtbTanixAndroidStock.zip (38.6 KB)
Image:
