I read it again and cant find it. Pls help
You can try this 2 files. It possible you have remote the same as for x92 box
remote.conf (3.4 KB) copy it to \\IP\Configfiles
keymaps.xml (4.0 KB) copy it to \\IP\Userdata\keymaps
reboot
Descriptions for buttons here in remote session(check if you remote looks the same):
whitch version dtb.img are you using mine isn´t booting
I did try my old MCE remote (with usb dongle) and it works. So I did found in Coreelec configuration that no network connection is available (ethernet and wireless). Therefore I cannot access to Coreelec via Samba. Thank you for your help. I have downloaded your files and wait for a network connection to be available in future nightly builds.
I am using the one labelled for s905x2 in the tree folder. But only boots from the SD to USB adapter non from STB.
As I understand it there is only a DTB for the 2GB device in the dtb tree presently, so some changes will probably be needed to produce one for the 4GB device that you have.
ok wait for some one to do that.
anable to maque it boot.
try micro sd, and pen usb no luck
Do you have the same box as users above?
Tested on x96max 4/32g, (S905X2) fails to boot from sd card (Black screen), boots from SD card adapter via USB2 slot, no ethernet (1000mb port) or wifi. been using balbes150
Libreelec version on this box, so really please to see CE support coming to this device, Great work team!
Yes, x96max 4/32g
@Mobigeek, @ragico
4gb S905x2 users could try this dtb
g12a_s905x2_4g.dtb (71.3 KB)
if it works than please check ethernet
Edit: new link until it will be available in nightly:
try it in pen usb in port usb2 and 3 don´t boot, sd card don´t boot to.
did you rename it to dtb.img?
yes rename it to dtb.img
What method are you using for first start?
If Toothpick method doesn’t work for you, you can try Terminal Emulator method
i use Terminal Emulator method, i will try Toothpick. and report.
I tried. It boots from SD in the USB adapter connected to USB3 slot. No network connection shown in Coreelec settings. Either ethernet and wireless.
the same sd card in sd card slot and pen us in port usb2 and 3 dont boot for me
Does your box have 1gbit speed in Android?
