My Tencent Aurora 5X won’t boot from USB and I don’t know how he does it.
I’ve tried long and short presses, and one time it worked, but I have no idea how I got it to work.
The 5X does not support CE with stock Android.
You need to modify the bootloader environment so booting is enabled. This must be done by open the device and use UART.
What do I do? Any video links?
There does no how to exist.
Boot to Android and insert USB device.
Then dump/dev/env to env.bin on USB device.
Then you are able like in Ubuntu to modify this env.bin with fdtput and fdtget.
My 5X just died because the internal 5V are dead.
Do all users of CoreELEC on the Tencent Aurora 5X have to do this???
Maybe the Chinese Android do support it out of the box, no idea.
I bought it on the Chinese platform and it doesn’t seem to be working.
I’ve gotten into CoreELEC a couple times the last couple times, but I don’t know how.
But it doesn’t seem to help It shows the CoreELEC screen but it doesn’t work. I’m trying to set ‘coreelec=textmode’ in the config file, hopefully that works because I haven’t booted from a USB drive all day today.
安卓系统是最新的吗?我的5X只插上U盘的时候就能直接进入U盘系统了,或者在安卓系统重启下也能U盘启动,启动的时候不要连接其他硬盘。
excuse me。When Aurora 5X plays a movie, click pause to play again and there will be noise. Some films will not appear. Does CE run the same speed on USB3.0, USB2.0 and eMMC?
系统你进去过?进CE的时候不要连接其他硬盘,俩usb口都连着它就只进安卓系统
This is english speaking forum.
The short “white noise” after pause will happen by TrueHD?
I think kodi fill in some “zero” samples to get in sync with video and this make the noise I guess.
是最新的 但是我这个插上直接进系统
只插了u盘 其他什么也没插
But the Tencent Aurora 5X is also a Chinese-made box.
It should be normal to have Chinese ![]()
But here you should write in English.
I do have env partition dump which allows booting from USB. If this is needed.
There are more than 70 Aurora 5X using CoreELEC.
So I think just the correct Android firmware is need to be able to boot CoreELEC from USB.
你家腾讯官方群了吗,问问里面的人,qq群329212198
I’m sorry, because most of the time, the translation programs aren’t very reliable.
But I speak English most of the time unless another person initiates the Chinese language, and then the env file dumps.
And then the env file dump, which I think I might need, but I’m not very good at it, is there a video tutorial?
But now it seems that this is another metaphysical question ![]()
What version of firmware do you have?
Also, I’m not sure if the firmware updates are the same in China as they are in other parts of the world.
