TrustOnX TOX3 S905X4 my experience
Later edit: forgot to mention that I used a microSD Sandisk card for testing the .no variant (I will try also to deploy a dual-boot config though cemmc -x command).
Ok, I had some spare time to play with the box BTW it’s the 4GB RAM 32GB nand.
.no variant works better than .ne, on Plex add-on from panal and NFS shares. No skipped frames or stutter, nice colors, HDR logo kicks (hdr10 and hlg, DV it’s shady).
NFS worked from the beginning, samba needed a few reboots to get alive.
VFD works also, just don’t activate the extra settings (last tab I think).
Remote conf. works for me, I use a Minix A3 lite anyway.
Speed test in command line went almost to 700 Mpbs, dunno if I have Motorcomm chip.
Didn’t test wifi and bt, I use ethernet, to much noise in that area, even the tv it’s on wired connectivity.
So, until now I’m good with the .no variant, way better for me than .ne, maybe some better drivers and stuff with the new kernel.
Things are going to be fine when the final version will be available! Good job as always, CE Team! :beers:
Thanks for that information. I may give that NO another try on my TOX3 box.
I tried it when they first introduced the NO, but not useable at that time.
Tested the wifi - its working: wifi on TOX3
ceemmc -x gives only single mode installation on internal memory:
CoreELEC:~ # ceemmc -x
Starting CoreELEC eMMC installation tool...
System is not supported: sc2_s905x4_4g_1gbit!
There is NO official support by Team CoreELEC
if you continue to run this tool!
Continue? [y]: y
eMMC size: 0x000747c00000 [32GB]
No CoreELEC installation found on eMMC
Install in single boot mode, only CoreELEC on eMMC
  Use CoreELEC data from
    [3] current used SD or USB device
    [4] existing backup on current used SD or USB device
Install in dual boot mode not possible!
Please choose one option? [3/4]:
Ive just received my TOX3 . Great piece of kit. $78~ Australian from AliExpress.
Original TOX3 TV Box Amlogic S905X4 Android11 4GB RAM 32GB ROM BT AV1 1000M LAN 2T2R Wifi 2.4G&5G HDR Media Player Set Top Box
Tried installs of all the current NO, NG, and NE.
Had vc1 issues esp on NE. Tried latest NE nighty that came out today (20240404)
woo hoo, all working 100% atm :). Great piece of kit.
VFD works too. Added Open VFD from CE addon folder (in services).
Used this
vfd.conf (1.2 KB)
300+ on eth download :slight_smile:
Very happy so far.
I recommend this box going forward :slight_smile: Baz
