I have a bouquet file for DVB-T channels which are broadcast in this locale.
I can use that file successfully on tvheadend on my main PC, but both the tvh version and build type are different to the Tanix.
On my main PC (Intel i7) this version is installed and working
This is an open issue on tvheadend issues list. I think it’s something to do with how tvh is compiled for coreelec. I have tried to do a trace debug for other issues as well to no success.
Might be worth trying a le build seeing if the issues persist
I used the Generic image from that page and tested it, and the DVB-T channels worked properly in tvh.
That appears to narrow things down a little … ARM or OS build of tvh?
I dug out an old R-P 1 and installed LibreElec RPi.arm-8.90.005 on it.
I did only a quick check … the R-Pi 1 does not ‘run’ but slowly walks through things
Unless I made an error with the Bouquet path, the problem is there also.
Yes I did (on an x86_64 PC as it would not run on an ARM device of course) … not sure what your point is?
I have only found the problem with ARM builds - both CE & LE.
. EDIT:
For clarity I have done the following installs and tested the same two bouquet files on them all with results as reported
LE to R-Pi 1 (two LE versions) DVB-T does not work
LE to R-Pi 2 DVB-T does not work
CE to Tanix Tx3 mini DVB-T does not work
LE to X86_64 PC (latest Generic image) **DVB-T does work**
The DVB-S bouquet file worked on all.
From this there seems to be just two areas in common
CE being forked from LE might well have the same problem with the ARM build due to shared code.
Lots of views of this thread (250+), but only two of us participating unfortunately, and both of us have the same problem.
It would help if another could test with an E2 style bouquet for DVB-T channels.
Hopefully one of the devs who is familiar with the tvheadend build for CE will post and let us know their thoughts on this.
I am beginning to think no one is using CE to watch terrestrial tv.
I opened a thread on LE also, but have not had any better luck there.
Bug #5387 on tvheadend does not even have anyone assigned to it, so I guess it is not getting any attention there either.
This link was given for the relevant code
Maybe whoever builds tvheadend for CE could have a look to see why DVB-S entries have no problem being automapped but DVB-T entries all fail to automap?
There is a bug report open on tvheadend but I was unsure about how this all becomes available in CE.
So no patches applied, but what about the build? For instance, is there maybe some build option that is accidentally omitted when the package is built for ARM/CE?
It does seem strange that this functions as expected in X86_64 builds I have tried, but not in ARM builds. (I have tried LE X86_64 and ARM, and CE ARM)
Anything you can add would be appreciated, thanks.
and essentially abandoned as it was apparently an upstream problem.
Not a lot has happened since, but this post provides some hope that tvheadend devs are willing to look at it.
Maybe if we could get a rebuild of the tvheadend server addon which includes this patch, some useful information might be provided to the devs which could help resolve the problem.
Is this possible?
Does anyone have the time and capability to do this?
I am very willing to test if it can be done.
Thank you.
(the old thread is closed so apologies for starting a new one)
