Ugoos AM6 B plus - no audio passthrough option
@Portisch
New image tried…
Boot = OK
Wifi = OK
Audio passthrough = not OK
Log: http://ix.io/3upC
Please check…
@zeeya
Please try again with CoreELEC-Amlogic-ng.arm-19.2-Matrix_devel_20210729212115:
@Portisch
YES…!
It is working…
Boot = ok
Wifi = ok
Audio passthrough = ok
Thanks for the great support and quick responses…
What next…?
Should I use the above build as my daily driver or I have to wait for it to merge into the regular update path?
Please clarify…
Thank you for testing. It will be soon in nightly.
Can update to nightly from this version?
Yes, once the nightly contains this fix, just drop the tar file into the Update folder and reboot.
Thanks a lot for your support
super great work you guys. question how will we know when the ‘nightles’ has this fix in it, as normally nightles don’t list a bug fix do they?
You can usually see it in the commits list on the nightly page.
The changes should be already included with tomorrow next nightly. Thank you for testing and support CoreELEC.
We appreciate CoreELEC team’s hardwork in solving the issues related to AM6B device.
Firmware for the said device is available as nightly build now…
@Portisch Bonjour le fichier n’est plus disponible, en fait je vais recevoir une am6B plus et je voulais savoir à quoi servait ce fichier premièrement et deuxièmement comment avoir le dual boot sur cette box car novice en la matière, et dernièrement dans les téléchargements quelle est la différence entre la version 19.4 matrice et la 9.2.8 héritage ? Merci
L’anglais est la langue officielle du forum.
English is the official forum language. This is so everyone, regardless of their origin, can participate and benefit from the experience.
Google translate
Merci.
@Portisch @Betatester Sorry I hadn’t seen, hello the file is no longer available, in fact I’m going to receive an am6B plus and I wanted to know what this file was for first and second how to have dual boot on this box because I’m new to the subject , and lately in downloads what is the difference between version 19.4 matrix and 9.2.8 legacy? Thank you for helping me
@Portisch Hello I ordered an am6b plus and I wanted to know how to have a dual boot with coreelec or how to install it either on the box or on an sd card because I’m new to the subject , and lately in downloads what is the difference between version 19.4 matrix and 9.2.8 legacy? Thank you for helping me
Maybe it’s better to buy a device from the supported list?
The Ugoos dual boot system is not supported by CoreELEC.
9.2.8:
@Portisch Thank you for answering but in the 9.2.8 download there are two versions for am6 ugoos, rev A and rev B, what is the difference and can I put one of these two versions for example on a micro SD? Thank you, you had found a solution for the person above in the discussion
9.2.8 is not your case as it doesn’t support AM6B(or partially supported)
rev. a and rev. b are g12b SOC’s revision
Plus version usually was rev. b
@boot2k3 ok so that means I can’t have coreelec?
