Ugoos AM9 Pro - SoC S6 S905X5-J
New Ugoos AM9 Pro with Dolby Vision
See: Ugoos AM9 Pro
required dovi.ko (460.8 KB) for DV MEL only
reference: Ugoos AM9 Pro - SoC S6 S905X5-J - #14 by crazyturk
For DV FEL support CORRECT dovi.ko module must be used, more info from: FEL - Amlogic NO support - #3 by vpeter
working DV FEL module: 5.15_2.6_dovi_patched.ko (460.8 KB)
another one which should work better: 5.15_2.6_dovi_patched_fix_fel.ko
Seems like ugoos put up the am9 pro on their website.
Sadly just 4gb ram but with dv
It´s enough
hello, is there a current working dovi.ko for the AM9 Pro (latest ce-no nightly)?
thanks in advance
Not yet. Device is on the way to devs.
Last Firmware:
Android 14 Ugoos AM9 PRO Firmware v. 2.0.6
1. HDMI CEC fixes
2. Fixed some system crashes
3. Fixed when to start screen saver setting
4. Added DV support for 1080p120Hz
5. Fixed color issues after playing DV and HDR content
6. Fixed some video playback in 4k120Hz mode
7. Fixed system freezes when using AI scaling
8. Updated Magisk
9. Some other system changes
2026-01-16
Hello, welcome back to the forum. I sold my X96 M200 device and bought a Ugoos AM9 Pro instead. It will arrive tomorrow. Is the dtb file for the Ugoos AM9 suitable for the AM9 Pro? Thank you.
I got my AM9 Pro device today.
I installed the CE and it’s working. I think the black screen on DV videos is because there is no dovi.ko file.
H266 videos are working.
Every time I restart it, it boots into Android and then boots into CE using the Reboot to Coreelec application to switch to CE.
Edit:When the dovi.ko file I used in AM8 was deleted, DV videos no longer display a black screen.
The dmesg | paste command is not working.
CoreELEC (official): 22.0-Piers_nightly_20260220 (Amlogic-no.aarch64)
Machine model: Ugoos AM9
CoreELEC dt-id: s6_s905x5_ugoos_am9
Linux version: 5.15.170 (docker@72f88b952264) #1 Fri Feb 20 01:29:44 IST 2026
Kodi compiled: 2026-02-20 03:40:20 +0300
CoreELEC:~ # dmesg | paste
503 Service Unavailable
Hello,is anyone alive,can I write a complain?
Btw I have Ugoos AM9 Pro.It is complete copy of AM9.
Didn’t Ugoos send you both of those for free to review, why complain :grin:
The Pro uses LPDDR5 (vs LPDDR4) and is Dolby Vision licensed. It might also include BT 5.3 vs BT 5.2 on non-pro, but that might be a typo.
I had 1 annoing unread notification here,which I couldn’t get rid of,because you know,coreelec was read only for so long.
But in terms of difference between pro and none pro,DV yes,ram has same speed of about 8GBps,so in terms of benchmarks they are quite identical.
The dovi.ko file for AM9 Pro is for training and testing purposes.
dovi.ko (460.8 KB)
link
Only normal reboot from Android is enough.
The cause of this issue is not yet known.
connection error
cURL error: (7), Failed to connect to paste.c-net.org port 443: Connection refused
CoreELEC:~ #
Will be looked and fixed soon.
If it is DV licensed, also with FEL or only standard MEL
Why? FEL is only for Blu-ray player with physical disc. Is there any box with a Blu-ray drive available? No, so no FEL.
AM6B+ is not Blu-ray player with physical disc and having DV FEL
