hello, i’m using am9 pro with latest nightly
DV FEL isnt working anymore, maybe a correlation with the dovi.ko file? i’m using the file posted at the begining of this post.
Use correct module as written in first post (updated right now). More info at
But seems you are already using correct module.
hello, thank you for responding.
i tried to replace my current dovi.ko with that one https://discourse.coreelec.org/uploads/short-url/5JeaPC2keKEnMgjCf25WPFrNKPC.ko under /storage/.config/dovi.ko via ssh
that did the trick and FEL is working again - thank you for that
but when i stopped my FEL example (alien: romulus) CE only showed a small pixeled window with wrong colors and froze
First thing is to check on clean system.
i will try a fresh installation with the patched dovi.ko
Dear, for AM6B+ with NO, which is the correct version of the dovi.ko module I should use?
Read first post again.
Perfect, now there’s a dovi.ko module just for DV MEL?
this is only am9 pro, if you are looking for am6b+ look in other thread
It was only for MEL in the past but now also FEL is supported but different module is needed.
seems working flawless after new installation
im getting a black screen with HDR10 content just a flickering HDR logo in corner then no signals after awhile, audio carries on
You have AVR in the middle. Some of cables could be bad for high bandwitch , try direct connect with different cables and you will find a reason.
So i went back to the hdmi cable it came with and changed back to enhanced and now its fine, very strange, thought 2.1 cable would be better
Should I update the box to firmware 2.1.0? (Currently on 2.0.9). Has anyone else done it, and it’s OK?
I’ve only seen the update message because I’ve had two spontaneous reboots in CE NO and it rebooted to Android. Nothing I could get to reproduce with logging though.
FW 2.1.0 works ok, booting from sd-card correctly every time, no spontaneus reboots so far, after using AM9 pro a couple of days. Hoping install to emmc works someday in the future.
EDIT: Install to emmc succeeded using secret highly dangerous code
System is crashing while trying to access my source set as TV shows, changing it to Movies seems to fix it. am on the latest nightly
Roll back to previous version
See Amlogic-NO topic for details about issue.
A post was merged into an existing topic: Amlogic-NO discussion
