tried to install the latest nightly on my old 905X box (Mecool M8S Pro+). Flashed CE on sd card, copied gxl_p212_2g file from the provided distribution tree folder to the root directory and renamed it to dtb.img. So far so good, passed the distributors logo and goot a message saying “device tree is out of date”.
I am quite puzzled, because i am pretty sure that this is the correct dtb file (since i passed the distributors logo), so i do not really know what to do. It IS the most update dtb file that I could have or am I wrong there?
You will have to redownload the image and reburn it again because I have just done a fresh install on an S905X device and can not reproduce this, the only way this would be repeatable is if you are using an old LE device tree.
Thanks for your help. This helped me fix the boot message “your device tree is out of date”.
I had updated from libreelec 8.1.5 to coreelec 9.2.2 and suffered from the missing device_tree.
I searched for the procedure, but couldn’t see the recommended way to clean up an existing install.
I have CoreELEC 9.2.2 installed on internal on my Beelink MINI MXIII II. What’s the easiest way to make it “clean”?
Can I do this just with ssh?
What kind of issues will the remnants of LE cause?
