X96 Max+ front lcd display
Does anyone have (I don’t know what) [config, script, driver]?
for the front panel?
Model:
X96 MAX +
4GB + 64GB
Android 9.0
Amlogic S905X3
Thanks, but it doesn’t work
cat /sys/kernel/debug/gpio | paste
http://ix.io/1RIM
So which VFD.CONF have you used that doesn’t work ??
There is a x96-max-1gbit-vfd.conf ???
We can’t just guess what you’re doing.
You need to run that command in Android Terminal
Yes ! there
what’s to guess…
I want the display to start when CoreELEC is started
I downloaded a few files (GitHub - arthur-liberman/vfd-configurations: vfd.config - A collection of configuration files for linux devices with a front facing display.)
by following: (# This file must be renamed to vfd.conf and placed in the /storage/.config/ folder.)
it still does not work
I don’t care about the fully functional display in CoreELEC, I just want to know that it turned off or starts
@ TheCoolest
info from termux
$ su
:/data/data/com.termux/files/home # cat /sys/kernel/debug/gpio | paste
gpiochip1: GPIOs 410-495, parent: platform/pinctrl@ff634480, periphs-banks:
gpio-448 ( |amlsd ) out hi
gpio-458 ( |amlsd ) in hi
gpio-474 ( |data_gpio ) out hi
gpio-475 ( |clock_gpio ) out hi
gpio-482 ( |sdio_wifi ) out hi
gpio-483 ( |sdio_wifi ) in hi
gpio-493 ( |bt_rfkill ) out hi
gpio-495 ( |bt_rfkill ) out hi
gpiochip0: GPIOs 496-511, parent: platform/pinctrl@ff800014, aobus-banks:
gpio-498 ( |avout_mute ) out hi
gpio-506 ( |stb_gpio ) out lo
gpio-507 ( |? ) out hi
https://paste.kodi.tv/ejadivaces
Hi Salesi, I have a X96 Max + and I use the below vfd.conf and the display works perfect.
x96-max-vfd.conf (1.2 KB)
Great
thanks !!!
now it shows the time and I know it’s off
I can’t guess or read your mind.
Really sorry about that
So can you let us know where you got this working vfd.conf from ?
I don’t see it named as you have named it in the downloads
Is the correct file. You just need to download it as raw, not as HTML.
kostaman, the vfd.conf file came from Jul 19 post from TheCoolest. if you search the forum posts with ‘x96-max-vfd.conf’ the post and thread will come up.
I didn’t realise until recently there is a vfd addon, which you need to install.
With that you can configure the display
and that’s what I needed
the addon works perfectly on my box
x96 max+
