Any idea how to install Emuelec on a X96 Max Plus? Anyone else have it working?
Use forum search!
Where is the reset button on the X96 Max? I am having problems getting emuelec to boot, mine is stuck on the boot screen.
Stick a toothpick in the AV port. You’ll notice there’s a switch (quite deep inside).
For the record, I have similar problems with a recent X96 Max Plus 4G/32G/1000M. My box, though is a Q2, with a firmware 20201209-1446, look here for my report: Boot issue with X96 Max Plus Q2 4G/32G/1000M (stock firmware 20201209-1446)
Dont unzip the image. Burn the zip file you downloaded
