I would like to install CoreELEC 9.2.2 NG to my X96 Max (S905X2) 4GB/32GB/1Gbit so I download the right CoreELEC image and use the g12a_s905x2_4g_1gbit.dtb (renamed to dtb.img).
It boots correctly, I can use CoreELEC but ethernet doesn’t work. I get a private address 169.254..
Also, the remote and the VFD don’t work but perhaps it’s normal ?!
If I use Android, I can get remote, VFD and Gigabit working.
Is there another DTB to try ? Is remote and VFD should work out of the box ?
Thank you !
No they don’t.
Thank you, I’ll look at it when ethernet issue will be solved.
I found the same issue here : Gigabit LAN driver problem
