SOC s905y2 can be started normally, but USB device, WiFi, etc. cannot be recognized.
Using the DTB file of s905x2 RAM 4g
Is this your hardware below?
X96S TV Stick Mini PC TV Box Android 9.0 Amlogic S905Y2 4GB RAM 32GB
2GB+16GB version only supports 2.4G Wifi+Bluetooth
4GB+32GB version supports 2.4G&5GHz Dual Wifi+Bluetooth
You will have to extract your android device tree and upload it here for the Devs to look at it.
<4GB+32GB version supports 2.4G&5GHz Dual Wifi+Bluetooth> itās that one
I wii be Try to extract DBT file
sir
I have system firmware
is that ok?
if you canāt be Download this
Iāll take about something else
https://pan.baidu.com/s/14nplRB0NXucApJzFV00W7Q&shfl=sharepset
ęåē ļ¼88xo
No good
If that is latest Android update ZIP for your box you can extract dtb.img from it.
Zip it and attach it here.
I donāt know if itās thisdtb (256 KB)
No that is not it.
You have to follow instructions as iāve instructed to extract the device tree from Android.
I CANāT EXTRACT dtb.img
I got this one_aml_dtb.PARTITION (55.3 KB)
Why canāt you ?
What method did you try to extract it ?
No good.
1
I try system update and I find the update.zip
i got the ādt.imgā
2 I find a "dtb from in /dev/ but it not img
3 i have a System ROM i try extract it in some method
but so hard
i just find aml_dtb.PARTITION
so sorry
Android Commands to Extract Device Tree.
One of the below Might Work.
You need to SSH into the X96s whilst in Android.
Using something like THIS
I havenāt done this for Sooooo Long.
Give it a shot.
dd if=/dev/dtb | gzip > /storage/downloads/dtb.img.gz
dd if=/dev/dtb | gzip > /storage/emulated/0/Download/dtb.img.gz
Then go to the downloads folder of the X96S and copy it and upload it.
dtb.img.gz (253.8 KB)
I GOT IT
How did you do it. ??
Which method did you use ??
According to your instructions
I Install the ājuice SSHā to the X96s
and āGive it a shot.ā
" su
dd if=/dev/dtb | gzip > /storage/emulated/0/Download/dtb.img.gz"
thanks for your halp
Maybe someone can clear my confusion ā¦
I have an X96x2 that I want to get the Android dtb from.
I rebooted from CE to Android; installed JuiceSSH
I attempted to SSH in from my PC to do a dd copy.
I ended up logging in to CE ⦠which confused the hell outta me.
I expected to log into Android.
I tried the dd command anyway and got a 0 byte file ⦠not unexpected I think.
Does the device need to be booted clean to Android and then SSH into Android?
Is there a login user/password?
I know ⦠simple when you know what you are supposed to be doing, but obviously I donāt
i got 0 byte file too
because no root rights
you have to input āsuā first
1 on the android
2 open the juiceSSH
3 Connecting local devices
4 input"su"
5 dd if=/dev/dtb | gzip > /storage/emulated/0/Download/dtb.img.gz
ps. without PC because that need the android Enable SSH service
I guess thatās all
Unfortunately I cannot gain root pribileges apparently
bash: /system/xbin/su: Permission Denied
Sorry i canāt help you
Iām just a vegetable sales
not Engineer
it has root ?
