OMG
It´s one simple click every day.
Very ungrateful of you
Next stable will include all changes in nightly, so yes, it’ll work with S905Y2.
@Tim_Taylor I answered in other thread… in my case, not a problem. But my parents will be confused with that, any popup or update at startup. Ok, waiting for next stable build.
Then you should of bought your parents a supported box instead of an unsupported one
You don’t say
but it seems support is coming, so it’s not as bad. I see no problems on nightly.
It’s exciting news. Thank you for you.
and I am Sorry,my job did not work.
Does sleep and wake up work for you? Not sure, but as far as I remember, that was ok on nightly, after upgrade to stable I am unable to wake up. Power off/on with remote works fine though.
wake up is doesn’t work
Today I’ve tried to boot X96S from an SD card with either g12a_s905y2_2b.dtb or x96s_2g.dtb provided here, but it both cases the booting is stuck at the initial splash screen. What could be wrong, how can I debug or log? Thanks!
I’ve tried multiple different versions of generic and “ng” images - nothing works on my X96S. However, TWRP for s905x boots normally. Such a broad failure makes me to think the bootloader is incompatible with CoreELEC at all.
@TheCoolest latest stable still does not Include g12a_s905y2_xxx in device trees folder. Isn’t it supported still on stable Coreelec? Also no S905y2 in download options to choose.
Where can I get dtb suitable to latest stable CE version?
g12a_s905y2_2g.dtb g12a_s905y2_4g.dtb
I see both files in latest 9.2.5
I installed stable generic img image on my sd and there’s no these files
Have you used -ng?
No, generic. Ng is not installable on sd, not using method mentioned in CE docs
S905y2 is Amlogic-ng
How to install ng on sdcard? That’s not installable image. Or should I get dtb from ng and put it to sd with generic installed
It’s this one: CoreELEC-Amlogic-ng.arm-9.2.5-Generic.img.gz
You burn the Amlogic-ng generic img.gz to your boot media. After burning you place the correct dtb in COREELEC partition
