19.0-Matrix Discussion
Thank you.
@bossanova808 I want to thank you for your persistence.
I read the discussion on git. I noticed kodi picking the wrong res settings resulting in…less than fluid behaviour and i think this will do it.
No worries. I figure if something is bugging me, and it’s not really obscure, it’s bound to be bugging others. And I like to help out if I can, even if it’s just describing the issue fairly properly.
I am not really into C++ and I haven’t got a Kodi buildchain set up anywhere, but in this case it was fairly easy to just read through the logs and the code to see what would be happening.
I do really dislike jerky playback…
Hi I have 2xOdroid-N2+ with Matrix 19.0 installed + MCE remote.
Unfortunately the fast forward / reverse doesn´t work well. Sometimes the upper video clip slider doesn´t move to the actual chosen position, sometimes it jumps to that point but fails to play smoothly the video. Only choppy video pictures to see. Before Matrix everything was ok.
Tested with initial Matrix (3.3.21) and CoreELEC-Amlogic-ng.arm-19.0-Matrix_nightly_20210311 from today.
I can confirm. It doesn’t matter if I use my mce remote, tv remote or the UI buttons. When I hit play afterwards, the video isn’t at all smooth, but stutters. Only stop/start works.
@roterdrachen @bhf No logs no problems.
There were some important changes in simple iptv addon: https://github.com/kodi-pvr/pvr.iptvsimple/commits/Matrix
Can you build and bump version?
Hi here is the log: http://ix.io/2StQ
I took 2 video clips and fast forwarded the timeline with my MCE remote, after forwarding often no picture at all or choppy playback. Or black screen. Hope you can fix that. Before Matrix timeline seeking was fine. I´ve tested with different video clips and formats. Always the same errors.
Please also upload ce-debug output to check you config
Massive improvement in 0311.
Reduced the incidents to nearly none.
There were a couple of hiccups over the course of few hours but nothing that would warrant further action IMO.
Thank you.
Bump on this. Any dev’s have any ideas or what other information do you need? Bluetooth audio worked in 9.2.x but not in -ng builds.
As minimum you should switch off sync playback to display first and try.
If still doesn’t work then please try to update to current nightly and check if it works.
If still not, collect full log on nightly build.
Enable debug logging in Kodi and try to pair your BT device
Then run pastekodi and ce-debug again and post the URLs you receive.
hy please help how to build?
what kind of ubuntu is needed for him a what kind of packet there should be telepítve?ilyen a command is needed for him? x96s905xbox
Supports CoreELEC 19.0 Matrix Dolby Vision? DV works for me on Android TV Kodi 19, but CoreELEC 19.0 Matrix DV does not work.
Next time search the forum: not possible at the moment. And doesn’t seem to be in near future (or ever)
please wait…
X96 S905x 2gb/16gb tvbox builder.
Wait for what?
If you’re hoping to install CE 19, or any NG build to that box, you will likely need to update the bootloader to something more modern. With the bootloader used on the provided Android 6 you’ll get odd system lockups. The box may boot but be mostly unusable. I have an android 7.1.2 firmware that I installed to my X96 2/16 and allows me to run NG builds without errors.
what it is not possible to mean by the question now? why is needed for a half to speak. you say things like that for which nothing his alley to the question. it was the question how I know it build the coreelec 19 matrices version x96 a905x because the coreelecen is the stable one here from a version downloadable
