A few days ago the only problem for users switching sometimes between stable and nightly was that the update procedure as described did not work. System still claimed no connection to repo and as a follow up the not updated pvr version stayed disabled.
Then I had contact to relkai here in the forum. He changed something and told me to download the nightly tar file again. Did that and installed the tar file. Then CE repo and CE nightly repo can both be reached again and all addons will be updated.
Some other Users had the same problem and could solve this with downloading newest tar files and doing a stable nightly stable or a nightly stable nightly change.
CE 9.0.1 stable/nightly both running like a charm used with my several devices.
@anon88919003
tried to uninstall and install but again āinstallation failedā even after your advice (says repository version 9.0.2) Is 9.0.2 coming today?
I understand there is no issue with CE, but CE update should include even the updated core repository so an update of the core addons provided by CE would not do any problem. Maybe I donāt understand something but for me itās logical that any system update should include even updated its core components.
I sorted the PVR-problems with deleting two repository-folders, but Iām still having issues with video plugins YLE Areena and CMore. I can browse list of videos, but playback fails.
I tryed this now serval times, but i get still the same error.
I see the requested URL in the Kodi.log. So i try to use wget on the odroid-c2 with the url in the log, which failed.
wget works. And it has downloaded the zip file.
This confuses me
2019-03-05 18:51:08.580 T:3987919728 ERROR: Requested path https://addons.coreelec.org/9.0/Amlogic/arm/pvr.zattoo/pvr.zattoo-18.0.63.0.zip not found in known repository directories
2019-03-05 18:51:08.580 T:3987919728 ERROR: CAddonInstallJob[pvr.zattoo]: failed to resolve addon install source path
2019-03-05 18:51:54.832 T:3530552176 ERROR: Requested path https://addons.coreelec.org/9.0/Amlogic/arm/inputstream.adaptive/inputstream.adaptive-2.3.15.0.zip not found in known repository directories
2019-03-05 18:51:54.832 T:3530552176 ERROR: CAddonInstallJob[inputstream.adaptive]: failed to resolve addon install source path
2019-03-05 18:52:14.924 T:3530552176 ERROR: GetDirectory - Error getting
what do you mean with āi tried thisā¦ā ?
The procedure from AdamG or the solution I have posted ?
The log file part you have posted is pointing exactly to the problem which should be solved if you try my workaroud as posted above. It is confirmed as working in postings at kodinerds also.
We bumped PVR API versions to make PVR addons work correctly after adding IPTV Archive support. A user suggested a better way to implement archive support, so we have now reverted back to following Kodi PVR API. This has caused these issues that some people now have. We thought itās better to deal with this problem right now and get everything sorted out before Kodi bumps their PVR API, which would have caused even more problems down the line.
I have the same problem with a Samsung TV. No issues with previous auto-updated versión (I donāt know wich number was, I think it was on the 8.9x.y branch) Solved with this workaround, after reboot too. Is there any open discussion for this problem? I can provide my debug logsā¦
I am trying to download CoreELEC-Amlogic.arm-9.0.1-Generic.img, download starts but it stops somewhere at around 5<30%, might be an issue with servers?
Hi! Iāve been using CoreElec on a 2gb LePotato for a few months now and itās amazing. But, on 9.0.1, the whole thing freezes after a few minutes of playing any video and I canāt find why. I tried playing locally, through a network, different resolutions, etc. and I could only solve it by installing the LibreElec 9.0.1 image, which works well but doesnāt support 3840x2160p. So Iād like to stick with CoreElec. Is there any way I could help to find the bug?
@DBraun either you are using an old version of CoreELEC or you have not followed the instructions in my previous post here as according to the log you provided, the URL that your device is trying to get the addons from is wrong.
Hi again! I ran some tests and the crash happens when the CPU reaches 100% usage, the whole system freezes and I can only shut it off from the power supply. Logs donāt show any error, probably because itās not Kodi related. Thank you in advance!
