libCEC component in kodi debug logging is not activated
@vpeter Playing from manual NFS share works fine, no stutter at all.
What is the difference between the manual share and the share created within Kodi?
Manual NFS share from OS is the best option, I use it always.
NFS access inside KODI is like a miracle.
@Tim_Taylor You might be right… nevertheless this is the first time I got this issue. It was working fine until CE 9.2.5
9.2…7 This is a good new ! Thanks for your work team CE ! I will wait for this update to update from 9.2.5
There is something wrong when I click Download 9.2.6 Legacy I get matrix link for T95Max Plus do that mean if I update via CE it will download / install Matrix ? Already ask yesterday but that’s seem to be something wrong there
I got this issue a few years ago using raspberry pi.
Got the advice to mount my NFS(NAS) share from OS and this works until now.
libCEC activated http://ix.io/2RFo
2021-03-04 15:30:08.400 T:3780584320 DEBUG: CecLogMessage - Broadcast (F): osd name set to 'Broadcast'
2021-03-04 15:30:08.401 T:3780584320 DEBUG: CecLogMessage - connection opened
2021-03-04 15:30:08.477 T:3780584320 DEBUG: CecLogMessage - processor thread started
2021-03-04 15:30:08.477 T:3780584320 DEBUG: CecLogMessage - << Broadcast (F) -> TV (0): POLL
2021-03-04 15:30:08.477 T:3780584320 DEBUG: CecLogMessage - << f0
2021-03-04 15:30:08.482 T:3780584320 WARNING: CecLogMessage - Write: write failed
2021-03-04 15:30:08.482 T:3780584320 DEBUG: CecLogMessage - << f0
2021-03-04 15:30:08.504 T:3780584320 WARNING: CecLogMessage - Write: write failed
2021-03-04 15:30:08.504 T:3780584320 DEBUG: CecLogMessage - >> POLL not sent
2021-03-04 15:30:08.504 T:3780584320 DEBUG: CecLogMessage - TV (0): device status changed into 'not present
TV CEC is not active. No response from TV on the ping f0.
and why it works in version 9.2.5
I also know that it is not possible in version 9.2.6
sorry my glass bowl is out of order
v 9.2.5 no problem http://ix.io/2RFy
ok, let me make a test image for you
it doesn’t work in the Matrix either probably the same bug as in version 9.2.6 http://ix.io/2RFM
N2 and CEC works here without issues.
@forsajd please try todays nightly. Doesn’t matter if 9.2 or Matrix.
Thanks for mentioning this. There was a few little bugs in the legacy download page source code.(You stay up to late working on something and you end up making typos) This should be resolved now, and the right download file should be offered for 9.2.6 legacy now.
yes …thanks for your work… I will wait for 9.2.7 8-))
It already works, the HDMI CEC was blocked by an HDMI cable, but not the one that was connected to the N2, but another, coreelec was fine
Also having similar playback issues on 9.2.6 on my ODROID N2 that others have reported in this thread.
Whenever starting a file from a samba share, the video would start playing for a few seconds with no sound, then the video would freeze up, but the subtitles and the playback timer would keep going. If I try to stop the video then, the UI would freeze up and I would have to powercycle the device.
One thing I have noticed is that if I pause the video while in that initial few seconds, and seek back to the beginning, the video would then play with no issues.
I just rolled back to 9.2.5 and have no issues with playback again, will just stick with 9.2.5 since the 9.2.6 changes don’t seem to benefit me too much.
why the heck you would write this?
If you are not willing help devs to fix an issue, maybe would be better write nothing.
Is that so hard to enable debug, recreate issue, and then write the text with attached logs? The devs would definitivelly look on that issue. Statement “something is wrong I am rollbacking, bye” doesnt help anyone - neither you, devs, and other possible users also.
