Please also collect ce-debug output for current 9.2.6
Also please try clean 9.2.6 on different usb/sd card, enable whitelist and confirm if it’s working correctly or not.
If not then we will check later that could be the reason…
If it’s working correctly then please also collect ce-debug to check that could be different.
9.2.6 - whitelist off - video o.k.
9.2.5 - whitelist off - video o.k.
9.2.5 - whitelist on - video not o.k.
And here I don’t understand if you have the same issue in 9.2.5 with whitelist on or not?
My Magicsee N5 plus (s905x2) auto-upgraded on the wife today and the TV remote (CEC) stopped working. I found the original remote and downgraded to 9.2.5 to get her up and running again. What do I need to do to debug this I will upgrade later when the TV s not in use to find out what is happening.
Exactly the same problem with my SX905X board. Sound dissapeared then video freezed. I tried videos from SMB source and streams from youtube, with same results.
Anyone can give me a hint how to return to previous version?
Edit: I found it, in CoreELEC settings: disable Auto update, then choose Update Channel
Hi! How to safely downgrade to version 9.2.5? There was a noticeable video jerk in Live TV (some HD channels) after the update. Khadas VIM3L. Log http://ix.io/2QPV
Fully configured the required configuration for 9.2.6 - everything works fine. I haven’t done a clean install for a very long time, probably two years. It is significant how the size of the backup file has decreased, it was more than 200 MB, it became - just over 40 MB
Ok, but it still need some clearing: so you mean I can simply update with the automatic OTA method to 9.2.6? Than switch off the Box, get the SD card and plug in to a PC, copy and rename the GT1 mini .dtb file to it’s place and than just put the card back to the Box? Or after the OTA update I can also copy the .dtb file to the Box’s SD card through LAN from the PC and than just reboot the Box? Thanks!
