Amlogic S905X2
In android the upload and download speed is correct. In coreelec there is an error in the software. The upload speed is very bad. In my photos it is appreciated. In wifi 5g android works fine but in horrible coreelec. By cable x96max it works well in ascent and descent of speed. It is clear that the network and wifi hardware are fine. It is a software problem in coreelec.
my test x96 max 4/32 eth and 5G wifi
Can someone of you tell me how to install CE on X96 Max 4/32? Ive tried with micro sd card that works on my EggoIggo, with and without dtb.img. Tried the same with usb stick in usb 3.0 slot, with and without dtb.img. Nothing seems to boot. I only get a blank screen or a bootloop. Tried it with toothpick method and terminal emulator. Nothing seems to work. Am i blind or did i miss something?
Using the latest NG-Generic builds.
Edit: The LibreELEC builds running and booting fine. Is there a faulty upload/build for fullflash?
very clearly coreelec wifi software doesn’t work well in this x96max
This fix has not been resolved with 9.2 stable. Gigabit lan driver problem is not the problem. The x96max works well ethernet network The error or failure is wifi driver problem
@Hanspampel
Here my one working H96 Max S905x2
[H96 Max S905X2 working Coreelec
Will the S905x2 be CE to NAND?
No internals for S905X2
Having new revision of X96 Max 4/32.
Coreelec is booted from USB3.
When I do reboot from Coreelec or Android - I get into Android system. When I plug power - I boot to Coreelec.
Is it possible to boot Coreelec from reboots, not only power on?
@elgatito, have you tried from SD card?
I don’t want to use sd-card, because the speed of sd-card reader is sometimes 10x times slower than USB3.
Class 10 card is more than enough for CE
Can someone please share with me if hyperion ng works with s905x2?if yes please share a guide for me to configure it…i am a newbie!thanks in advance…
Is it similar to this one?
[H96 Max S905X2 working Coreelec]
I have tanix tx5 max and latest build has no wifi and bluetooth. What should i do?
Did earlier builds have wifi and bluetooth? If yes, we need to know in which build it stopped working.
I’m using this since 9.2.0 and i didn’t try any previous version. If you suggest an older version i can try.
Even i’ve tried latest 9.2.1 release today but nothing changed. My chipset is 6222B-SRB and rtl8822bs bt+wifi.
The 9.2.1 changes was only for GX* devices not G12*.
after update 9.2.1 s905x2 x96max isn’t upd gui resolution 3840x2160
what to do with the?
