Up to 1080p I’m afraid. CPU couldn’t handle 24fps 4k at all.
Anyone know the best place in the UK to buy the ugoos am6b+ from?
Currently, only the S905X4 and T7 devices can support AV1 at 4K decoding and CoreELEC.
Ive just received an TOX3 S905X4 from AliExpress $70au.
Playing all I can throw at it from my library.
Had to use NE 21 nighty that came out recently (20240404)with sc2 dtb that suits your mem and eth speed.
If the information from the internet is correct, this box is equipped with a µSD slot. Could you please run a test how fast the slot can read from a card ?
How do I do that?
I did see ~600Mb download once using
script.speedtester-1.1.3+matrix.1.zip (1.5 MB)
when I was connected to a good ISP.
Hi @Sunset1982 !
Did they finish implementing it ? Is it in CE 21.0-Omega ?
Asking cause I’m really itching to get my hands on a DV capable device ( the am6b plus in that case )
Yes, it is nearing perfection and should be stable.
For those seeking the Am6b Plus, the AM6 Plus is also an option if available new or second-hand. The only difference is the slower Wi-Fi speed. B variant is Wi-Fi 6.
I’ve bought from there, no issues and arrived in the US in about 7 business days.
im trying to setup the same but not having much luck.
What do you mean trying to set up the same. Same what, What setup?
Confirming it’s legit, received it one week later.
Hi buddy, can you help me install rclone on coreelec 21,i believe you got it working, right? Please head over if you can, thanks.
Do you know if HDMI-CEC works for the Vontar X4, so I can control it with my TV remote?
It does work. Never had a problem with this.
Hey guys,
I need a suggestion please for a box with fast ui and giagbit lan as I mostly watch 4k remuxes. Dolby Vision is not important as my Samsing S95D wont’t support it anyway.
Is there anything cheaper then the Ugoos AM6B+?
Odroid N2+ is basiclly an AM6B+ without DV.
With new builds you can add player-led dolby vision onto HDR only TVs similar to $$$ HDfury devices.
So you would be able to add dolby vision onto your Samsung provided it is HDR capable. If that sounds interesting, you should still get the Am6b+ to take advantage of that
