rc2 with standard dtb.img works
rc3 with extra dtp.img works
rc3 with standard dtb.img does not work
all fresh virgin installations
@sesotso please update with this test image:
You can easily do it with SSH:
cd .update
megadl https://....
sync
reboot
Then after update and reboot check if ethernet is working like rc2. There is no need to exchange any dtb, it will update itself. You can confirm if the correct dtb is used by:
cat /proc/device-tree/ethernet@ff3f0000/auto_cali_idx
The result should be 0.
Ethernet works
Ethernet after waking up works
cat /proc/… returns NULL NULL NULL NULL
CoreELEC:~ # CoreELEC:~ # cat -n /proc/device-tree/ethernet@ff3f0000/auto_cali_idx
1
2
3
4
CoreELEC:~ #
So the test image do work without issues?
It looks like a G12B rev.a issue only.
In my opinion everything is working fine.
And yes, my Beelink is rev. A.
The fix should be included in next nightly 20221223, please update with the build and report back.
No need to exchange the dtb.img anymore.
CoreELEC-Amlogic-ng.arm-19.5-Matrix_nightly_20221223
eth works with no issues
eth after waking up works with no issues
m3u playlists don’t work (unable to read playlist, reports 0 Bytes), in rc3 no problem
Please continue here:
