I see this issue with the current LE master as well. If I use smb://host_name/ it tries to connect to the wrong ip address. Had to replace the host name with an ip address.
thanksâŚgood to hear its not just me!
Just tried on a N2 and C4 with latest nightly (16-01) and it resolves and connects fine by hostname.
Not saying you dont have an issue; i just cannot reproduce.
i am using the generic image, as i am running on an old s905x Mini M8s II. maybe the issue is just with the generic image. for me it was the 16/01 release that introduced the issue, all was fine before that. doing a clean install on a spare SD i had rather than update with tar didnât help eitherâŚ
Some minor feedback on CE Settings with CoreELEC-Amlogic-ng.arm-19.0-Matrix_nightly_20210116-Odroid_N2. I am unable to change the âWait for network before starting Kodiâ value. It starts with and continues to display 10 after changing it to any other value. This isnât an issue for me as 10 seconds works fine, but just noticed it while messing around.
Can you see if you have any hosts blocks in your advancedsettings?
https://github.com/xbmc/xbmc/pull/19040 changed smb dns lookups just before RC1 which it looks like CoreELEC rebased to before the Jan 16th nightly.
Will be fixed in next nightly.
thanksâŚi checked and dont think so, contents of my advanced settings below (with some > removed so you can see what is in!) - is there an entry i can add that will have kodi resolve correct IP in place of 10.5.0.2 address it currently tries to connect it - note i have already tried adding ip and hostname (hostname 1 only) to my hosts.conf to no avail
advancedsettings
cache
buffermode4/buffermode>
memorysize313524224/memorysize>
readfactor>5/readfactor>
curlclienttimeout>10/curlclienttimeout>
curllowspeedtime>10/curllowspeedtime>
/cache>
samba>
clienttimeout>30/clienttimeout>
/samba>
gui>
algorithmdirtyregions>2/algorithmdirtyregions>
/gui>
videodatabase>
type>mysql/type>
host>192.168.0.10/host>
port>3306/port>
user>xbmc/user>
pass>xbmc/pass>
name>leiavideo/name>
/videodatabase>
musicdatabase>
type>mysql/type>
port>3306/port>
user>xbmc/user>
pass>xbmc/pass>
name>spmc5_music/name>
/musicdatabase>
videolibrary>
exportautothumbs>false/exportautothumbs> <!-- Export auto-generated thumbs. Default = false. Change to true to allow export -->
importwatchedstate>true/importwatchedstate> <!-- Import Last Played and Play Counts. Default = false. Change to true to allow import -->
importresumepoint>true/importresumepoint> <!-- Import Resume Points. Default = false. Change to true to allow import -->
/videolibrary>
/advancedsettings>
Hey! I have possibly a working solution for the CEC bug on Odroid C4 / N2 / N2+. Portisch helped me with this. After that I will try to enable bluetooth again, pair it and try to see this Kodi Settings addon not ready error again.
Thanks, currently i just use the backup addon to write to my PC for Kodi back up, will have a play with the corelec version. i use mysql on my PC as central DB for all my Kodi installs around the house tho, so donât think this will back up any of the manual fixes i did on my music lib if i need to start from scratch with IP instead of host name on my sources. exporting the music lib in kodi doesnât give me the .nfo in relevant media folders like it does when i export video lib, although not tried in 19 to see if any change there
thank you sooo much! i checked the wiki for advanced settings and added a hosts entryâŚit fixed the issue. now kodi connects to correct ip when using host name in place of the spurious 10.5.0.2 address it was using before, and i can play back library items again
thank you thank you thank you!!!
Are there videos showing whatâs new in Matrix ?
not seen any videos, only notable change i can see is that simple iptv client now has time shift, pause and rewind functionalityâŚfor me that was a big upgrade and allowed me to ditch NextPVR that was good, but took too much maintenance. now i donât have to worry about updating each week to keep channels in sync, it happens automatically without the need to even restart kodiâŚ
Thanks !
It seemed to me that the part dedicated to music had been improved as well?
anyone running other skin than estuary? if so, whatâs your experience?
nrpeton
Aeon Silvio, Amber, Unity all run smoothly with no surprising glitches at all.
Lyra bird mostly works fine.
Aeon Nox Silvo with lots of customization and artwork running well for me
Skin Aeon Nox Glass and Estuay MOD work on this CoreELEC version. For me they are better than the default ones.
