thx, @as_id next image (le_0206):
https://mega.nz/file/WLRCDLrK#1BIqWyCnOTCa1IPvBucx95DVo-n8Bsb6Nj6NWJcgdiE
http://ix.io/2Pk4 does not working
ok, looks like we come to a end.
next image (le_0205) will come soonā¦
Iām trying to use Librespot and although I can connect from the Spotify app on my phone to Librespot on Kodi, it does not play the active track. If there is a list of tracks it skips through them all until the end of the playlist and then stops.
Librespot is installed from the standard CE repository. Spotify app on my phone has worked without issue on CE 9.2.5 so at least the phone side seems OK.
Kodi log here: https://pastebin.com/QyzB7gqc
@as_id
please test this image(le_0205):
https://mega.nz/file/DeowCACS#BqTU0BJkJFaVAYUFQXD4qlzfWUTsPlOcwFTsVCusOfc
I guess it should workā¦
I did not doubt it
http://ix.io/2Pk6 does not working
le_0205? ok, let me make another image
@as_id next image (le_0205_e45aef1d87):
https://mega.nz/file/mGQXhSQA#ZS2G9fNrV63fGDZvuBDsfb8KG_UJsEA2AztVRcprxj0
We have really no idea what commit it breaksā¦
http://ix.io/2Pki WORKING!
@as_id
le_0205_a05b83c640:
https://mega.nz/file/nG4CEKhB#MEO61itf3LiFP296sXOhEsNOmR01WR5C7qVI119ctlw
working
http://ix.io/2Pks
last test for today @as_id:
https://mega.nz/file/CPpA2RbQ#nvjkI54fAmOXHejyVhmsm89oR4X-7ej8J7dNgNEq2QI
http://ix.io/2Pkx yes its working
We maybe identified the reason:
But itās strange as this should not affect our project as we use another linux package for Amlogic-ceā¦
@as_id please can you confirm this image is working?
(last nightly without ir patch):
https://mega.nz/file/PeRgCB5S#SklzfabGLU8jpTedgBiOXx3qRpcBfykv4xTYpmsTeCs
As my 18.9 on an Odroid C2 has massive issues with EPG using TVH as backend, Iāve installed nightly 19.0 on a cheap Tanix TX3 (S905X3). Seems fine so far.
My question is: will these release candidates also self-update automatically? Also when RC1 gets stable? Or will I have to update (i.e. re-install) manually when CE19 reaches stable?
No, it does not working http://ix.io/2PnL
Last working build was here CoreELEC 19 Matrix Discussion (Kodi RC1)
Yes.
Updating to stable is available as an option in settings
Gave up on the wifi adapter below.
Worked perfectly fine before most current nightly, but will not function stable anymore directly after updating.
Realtek Semiconductor Corp. RTL8812AU
Is there any changes in current nightly that might explain the erroneous behaviour �
