CoreELEC 19 Matrix Discussion (Kodi RC)
@Vodalex Are you using DietPi as your Nas?
Nothing has changed, KI Pro still does not recognize the tuner!
So when you run:
systemctl mask amlogic-dvb
It works?
Please reboot the device after mask/unmask cmd.
@joaolevi can you confirm this?
Yes, I did it on all three drivers
the result is the same, the avalink adapter does not appear in tvheadend
ps. so, i taked new sd and install new system
http://ix.io/2Pfh
http://ix.io/2Pfl
http://ix.io/2Pfo
after everyone i did systemctl mask amlogic-dvb and reboot
No, kobol.io helios 4
Ah, ok…it’s just that DietPi has had an update that effectively breaks NFS :frowning:
I have a RP4 running Dietpi as a Nas and suddenly none of my videos would play :- :worried: found out about the update malarkey.
Only solution at moment is to use smb (which I have and works)
Perhaps try smb?
Good Luck!
Smb works just fine. NFS seems to be broken.
Can you try this file? It includes a fix SMBFILE: Fixed samba FD leak on close by Karlson2k · Pull Request #19223 · xbmc/xbmc · GitHub
https://drive.google.com/file/d/1ItwikhsP0D6eItBSb2LVgxF8JORRWjw4/view?usp=sharing
@as_id @joaolevi
We need to try some images as I have no idea why it broke.
First is this image. It should be same as 20210210 nightly, so it should NOT work. Please confirm it NOT working:
https://mega.nz/file/vegESa5Q#Ln2P3ql-wnx7RCEpb5FWpFY3OCrYoq4LBMbRx4COyFE
CE-19 does have a mega.nz client included. You can easily update by:
cd .update
megadl   https://mega.nz.....
sync && reboot
I will upload another image soon what should be the status of 20210207 nightly.
Hi my internet friennd @Portish
i confirm about it doesnt working
http://ix.io/2Pji
i did all how you said
Here v1 what should be like 20210207:
https://mega.nz/file/yb5kmByb#VWkVwghGLUD91CQMonNLh8WXASa8bZizlt7AVQLjZ_c
Please run before update once:
systemctl unmask amlogic-dvb
Then update with this image with using megadl.
The tuner should work then after the update is finished.
YES, its working http://ix.io/2Pjy
Coreelec driver - no
Crazy cat driver - yes
Last kernel driver - yes
ok, thank you. now I need to create some other images to identify the commit what is the reason
GOD in helpfull to you
@as_id
Please test this image (le_0201):
https://mega.nz/file/uSAGHBzZ#3yn7T_W6M0fodLRlxpqVxqqQaGWPuDGsc5rtNXpVvow
All fixed, full library scan went through 100%. The power of an exclamation mark huh.
Thanks for your help and fast resolution!
Done, its ok http://ix.io/2PjW
@as_id
next image (le_0204):
https://mega.nz/file/WfoCmbrY#tAq8_JgEyOU6Vq243mv2dgXCtkevSemo6e14CP-cF8c
http://ix.io/2PjY working
