CoreELEC 20.0-Nexus_beta1 Discussion
About the Hyperion.NG: just run a manual update with latest version available. Then it should start running again. It also stopped here right now and did not work after reboot to. After update it’s running again.
The installed Hyperion NG will system work well if it is removed and re -established.
I just tried to upgrade from to 20.0beta1 (nightly build 20221119) and everything went fine.
But afterwards I was no more able to play DVD copies (VIDEO_TS) - “one or more items failed to play”.
There are a few messages in the log about libdvdnav not finding the stream.
Other files play well and after downgrading, the DVD copies are able to play again.
@vpeter This was the issue I mentioned here:- CoreELEC 20.0-Nexus_alpha3 Discussion - #32 by roidy
However this solution does not work for me:-
PS C:\Users\roidy> ssh root@192.168.0.13 '/usr/bin/sed -e "s|^export LANG=\(.*\)|#export LANG=\1|g" -e "s|^export LC_ALL=\(.*\)|#export LC_ALL=\1|g" -i /opt/etc/profile'
root@192.168.0.13's password:
sh: -c: line 2: syntax error: unexpected end of file
Update:- Seems it only works from a Linux or OSX terminal. Windows Terminal or Command Prompt doesn’t work.
Update went fine but I can’t play any DVD folders from SMB shares.
This is on a HK1RBOX S905X4 2GB/100M booting Coreelec 20.0-Nexus_beta1 from SD card, accessing DVD folders from either a Windows or Linux server. Tried latest nightlies, same problem.
DVD folder structure is typical VIDEO_TS containing .ifo and .vob files etc. The individual .vob files play fine, and the DVD plays fine from local storage (e.g. USB drive). Just not via SMB, which gives a “Playback Failed - One or more items failed to play” alert.
Log uploaded to https://paste.kodi.tv/cabataveje
Relevant log section below, looks like libdvd can’t open the .ifo
Hoping this is an easy fix.
Thanks, Jon.
2022-11-30 11:45:06.179 T:4053    debug <general>: OnPlayMedia smb://nasbox/Backup 5/MediaPC F/F-01 Music Videos/David Gilmour/2002 David Gilmour In Concert/VIDEO_TS/VIDEO_TS.IFO
2022-11-30 11:45:06.190 T:4053    debug <general>: CPlayerCoreFactory::GetPlayers(smb://nasbox/Backup 5/MediaPC F/F-01 Music Videos/David Gilmour/2002 David Gilmour In Concert/VIDEO_TS/VIDEO_TS.IFO)
2022-11-30 11:45:06.190 T:4053    debug <general>: CPlayerSelectionRule::GetPlayers: considering rule: system rules
2022-11-30 11:45:06.190 T:4053    debug <general>: CPlayerSelectionRule::GetPlayers: matches rule: system rules
2022-11-30 11:45:06.190 T:4053    debug <general>: CPlayerSelectionRule::GetPlayers: considering rule: mms/udp
2022-11-30 11:45:06.190 T:4053    debug <general>: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
2022-11-30 11:45:06.190 T:4053    debug <general>: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
2022-11-30 11:45:06.190 T:4053    debug <general>: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
2022-11-30 11:45:06.190 T:4053    debug <general>: CPlayerSelectionRule::GetPlayers: considering rule: streams
2022-11-30 11:45:06.190 T:4053    debug <general>: CPlayerSelectionRule::GetPlayers: considering rule: dvd
2022-11-30 11:45:06.190 T:4053    debug <general>: CPlayerSelectionRule::GetPlayers: considering rule: discimage
2022-11-30 11:45:06.190 T:4053    debug <general>: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
2022-11-30 11:45:06.190 T:4053    debug <general>: CPlayerSelectionRule::GetPlayers: considering rule: nsv
2022-11-30 11:45:06.190 T:4053    debug <general>: CPlayerSelectionRule::GetPlayers: considering rule: radio
2022-11-30 11:45:06.190 T:4053    debug <general>: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
2022-11-30 11:45:06.190 T:4053    debug <general>: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (VideoPlayer)
2022-11-30 11:45:06.190 T:4053    debug <general>: CPlayerCoreFactory::GetPlayers: for video=true, audio=false
2022-11-30 11:45:06.190 T:4053    debug <general>: CPlayerCoreFactory::GetPlayers: for video=true, audio=true
2022-11-30 11:45:06.190 T:4053    debug <general>: CPlayerCoreFactory::GetPlayers: added 1 players
2022-11-30 11:45:06.192 T:4053    debug <general>: Radio UECP (RDS) Processor - new CDVDRadioRDSData
2022-11-30 11:45:06.193 T:4053    debug <general>: Audio ID3 tag processor - new CVideoPlayerAudioID3
2022-11-30 11:45:06.193 T:4053     info <general>: VideoPlayer::OpenFile: smb://nasbox/Backup 5/MediaPC F/F-01 Music Videos/David Gilmour/2002 David Gilmour In Concert/VIDEO_TS/VIDEO_TS.IFO
2022-11-30 11:45:06.193 T:4239    debug <general>: Thread VideoPlayer start, auto delete: false
2022-11-30 11:45:06.193 T:4053    debug <general>: OnPlayBackStarted: CApplication::OnPlayBackStarted
2022-11-30 11:45:06.194 T:4239     info <general>: Creating InputStream
2022-11-30 11:45:06.195 T:4240    debug <general>: Thread BackgroundLoader start, auto delete: false
2022-11-30 11:45:06.203 T:4195    debug <general>: Loading settings for smb://nasbox/Backup 5/MediaPC F/F-01 Music Videos/David Gilmour/2002 David Gilmour In Concert/VIDEO_TS/VIDEO_TS.IFO
2022-11-30 11:45:06.213 T:4053    debug <general>: CVideoGUIInfo::InitCurrentItem(smb://nasbox/Backup 5/MediaPC F/F-01 Music Videos/David Gilmour/2002 David Gilmour In Concert/VIDEO_TS/VIDEO_TS.IFO)
2022-11-30 11:45:06.215 T:4239    debug <general>: SECTION:LoadDLL(special://xbmcbin/system/players/VideoPlayer/libdvdnav-arm.so)
2022-11-30 11:45:06.215 T:4239    debug <general>: Loading: /usr/lib/kodi/system/players/VideoPlayer/libdvdnav-arm.so
2022-11-30 11:45:06.221 T:4239    error <general>: Libdvd: Could not open smb://nasbox/Backup 5/MediaPC F/F-01 Music Videos/David Gilmour/2002 David Gilmour In Concert with libdvdcss.
2022-11-30 11:45:06.221 T:4239    error <general>: Libdvd: Can't open smb://nasbox/Backup 5/MediaPC F/F-01 Music Videos/David Gilmour/2002 David Gilmour In Concert for reading
2022-11-30 11:45:06.221 T:4239    error <general>: Libdvd: vm: failed to open/read the DVD
2022-11-30 11:45:06.221 T:4239    error <general>: Error on dvdnav_open
2022-11-30 11:45:06.221 T:4239    error <general>: CVideoPlayer::OpenInputStream - error opening [smb://nasbox/Backup 5/MediaPC F/F-01 Music Videos/David Gilmour/2002 David Gilmour In Concert/VIDEO_TS/VIDEO_TS.IFO]
2022-11-30 11:45:06.221 T:4239     info <general>: CVideoPlayer::OnExit()
2022-11-30 11:45:06.222 T:4239    debug <general>: Thread VideoPlayer 3368121024 terminating
2022-11-30 11:45:06.237 T:4197    debug <general>: OnPlayBackStopped: CApplication::OnPlayBackStopped
I can’t play DVD folders from nfs shares either. All other filetypes play OK. As do ISOs of the DVD folders.
I updated from Matrix to Nexus and had zero problems.
Good Day
I just installed a new image but sftp is not working and i cannot find the service / add on for it.
any advice please
I think you will have to provide much more info to even understand what is the issue.
Hi @vpeter
So in 19.5 i installed the sftp addon / service to allow me to connect to my shares. Now i cannot find this and connected via NFS.
So was just wondering if this has now changed.
EDIT: It was the Virtual File System Add-On in v19.x that I installed but do not see it in v20.x
Enigma2 PVR addon - very rarely shows the Live TV tab
Mostly it does not, which means I cannot execute the addon
Enigma works fine (can access it from any other device on the network)
Any ideas?
https://forum.kodi.tv/forumdisplay.php?fid=226
Thanks, but I have no issue with plugin itself, when the LIve TV tab shows, it works great. It is just that CE20 does not see it most of the time as PVR
Closed, please continue here:
Thanks, but I have no error. I just (most of the time) do not get the Live TV tab)
