Homatics Box R 4K Plus
Hi, does anyone have problems with CE-NG 21.2 stable? I tried it, but Kodi hangs after 10-15min Video playback and I see some kernel errors in the journal. Sometimes, after about a minute the device reboots. (Not just a Kodi restart, I see the Homatics boot logo) Kodi runs fine for hours as long I don’t play a Video. As soon as I play a video after 10-15min, it happens again.
journal log: https://paste.coreelec.org/BlouseNearing
Error happened at about 11:35h
With CE-NE I don’t have these issues. Tested with a pretty basic config, just mounted my nfs share and setup the mysql database connection. Also tried different USB sticks.
https://wiki.coreelec.org/coreelec:ce_support#basic_minimum
Team CoreELEC applies a “no log, no problem” philosophy.
Without feedback, we are unable to help you.
Hi frodo19, since you seem to be one “in the know”… is there now a “safe” Android 14 update to apply to the machine? I don’t use it for CE, just Android (have a separate Ugoos for CE) but the firmware situation is foggy to be optimistic…
You should wait. Currently Homatics shares V14 1782 on request. There are a few higher builds going around (zip recovery builds), you really don’t want to use. The currently “in test” 2463 build has reached Play Store approval, but still has several issues. One important fix, Sink LED, is in that build and the app blockage that is present in those leaked recovery files is also removed.
This is the current status…
When you in ATV12 no any reason to apply to the ATV14 .
The streaming apps work there too.
Mainly I was interested in multichannel PCM bug and quicker refresh rate switching (the box seems to change like three times before settling down). In any case, the above concerns Android so I’ll shut up.
Thanks for the info to both you and p750mmx. Much appreciated.
I have several homatics box, and just for the streaming apps, I not see any reason to using atv 14.
Hi
i am also facing some artefacts issues when playing a Dolby Vision FEL 7 Test File , i am using Dune HD HOMATICS Box R 4K Plus, with CoreELEC-Amlogic-ng.arm-21.2-Omega_nightly_20250224-Generic.img
This is only happening when fast forward or backforward video , i played large 90 gig files its not happening with them . or else generally plays well
I
I’m sorry, I’m not sure what I missed. Is it about the device configuration? I did a “submit Logs”, after the error happend. Of course, it’s from after the reboot, as I can’t do anything when the error occurs, so the Logs won’t contain many useful information, I guess: https://paste.coreelec.org/AcceptsEntrails
kodi.old.log is too big to upload completely, so I removed CVideoPlayer::ProcessVideoData and ::OutputPicture rows: https://paste.coreelec.org/FlunkedYanked
The last line was:
2025-02-25 13:01:47.780 T:4698 debug : CVideoPlayer::ProcessVideoData size:202901 dts:713.755 pts:713.
So the line has therefore not been written completely.
As I already posted, the Journal Log from the boot when the error happened and ssh was still working: https://paste.coreelec.org/BlouseNearing
I tried to get a newer journal log, but the last two times I tried, ssh wasn’t functional anymore and persistent journal isn’t configured in CE. The device rebooted in those cases on it’s own.
I guess I will just continue using NE. Afaik I’ll only lose FEL support, but since I want to upgrade to Kodi 22 when it’s released, I will lose FEL support anyway. I just thought that maybe someone had this problem before and knows what causes it. It’s weird, that NE works flawlessly, otherwise I would have thought it might be a hardware fault.
Here are my logs
https://paste.coreelec.org/GruesomeCedric
LG OLED C4
Problem : When fast forward BE_EL.MKV DV P7 FEL Test file getting weird artifcats , but just when i play it works well . only during fast forward i am getting whole screen pixlated , going black screen for few seconds .
Dune HD HOMATICS Box R 4K Plus (Rev D)
CoreELEC (official): 21.2-Omega_nightly_20250224
Feb 26 00:43:01.148836 CoreELEC kernel: dovi: disagrees about version of symbol module_layout
Feb 26 00:43:01.149052 CoreELEC kernel: dovi: module license ‘AML’ taints kernel.
Feb 26 00:43:01.149139 CoreELEC kernel: Disabling lock debugging due to kernel taint
Feb 26 00:43:01.149200 CoreELEC kernel: dovi: disagrees about version of symbol register_dv_functions
Incomplete logs are not acceptable.
Also samples are missing and how to reproduce.
For @Kju and @charu .
Read again the guide:
updated post
Still no kodi debug log or sample…
CEC disabled at Kodi?
Disable also on TV!
Was that using an attached hard drive or through Plex, or both? I seem to have that issue with hard drives but not Plex. I just got my box yesterday.
Hi, not sure if has been mentioned before, but I’m have trouble pairing the B21 remote. I’m on the latest 21-NG nightly and ATV14. When I try to pair the remote, CoreELEC essentially “crashes” from the bluetooth settings page back to the landing page, and the remote does not pair. Luckily my TV has CEC so I’ve been able to use that, but would like to get the Homatics remote working.
With the Dune you can copy the remote.conf into the root of the USB stick.
For Bluetooth use this thread.
When changing the version of CE (from NE to NG, for example) - can we just copy the old dtb.img file to the newly created usb drive? Or should we redownload the fresh version of the dtb file? I tried to use the dtb file from old CE usb drive, but it didn’t work on the new one, it wouldn’t boot. Maybe it’s the usb itself, I currently don’t have another drive to try.
NO. Every CE version has it’s own dtb.img file.
but if we have a custom remote.xml file, it must go inside the kodi filesystem somewhere, right?
